Focus Engine Management Light
Old Nov 15, 2009 | 08:59 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
Default Focus Engine Management Light
The engine management warning light on my wife's 1.4 Focus flickered on the other day when driving. It did if for about half a mile, then went out. It did it again when she started it this morning. It flickered for about 3 seconds and went out and hasn't come on since.
Are their any likely culprits to check before I give Ford far too much money to plug in their diagnostic electrictrickery - The car drives faultlessly otherwise.
Old Nov 15, 2009 | 09:03 PM
dojj's Avatar
dojj
Resident Wrestling Legend
if it's not on, don't worry about it
if it starts to flicker more often, then get someone to plug a machine into it, but possibly not ford
Old Nov 15, 2009 | 09:15 PM
t4 and greys's Avatar
t4 and greys
cosworth gimp
check the faultcodes yourself and see if any are thrown up ??
been a while but am sure you hold the trip reset down ,then switch ignition on whilst holding trip button ..
this will then start all the checks something like gauge check first then led check
will also show any error codes ,which can be easily looked up on the net
Old Nov 15, 2009 | 09:17 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
That gives only a limited number of codes unfortunately
Really does need a diagnostic scan to tell you more - interestingly though Dan, if you have a Superchips Bluefin lying around in the Fast Ford office - they do double up as a fault code reader for other Fords
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Focus Steve
Ford Focus Range
Aug 3, 2015 09:09 PM
Old ford
Jul 31, 2015 06:50 AM
