Ford Puma Discuss the Ford Puma here!
More Puma problems
Old Nov 15, 2009 | 12:41 AM
Ian2861's Avatar
Ian2861
Default More Puma problems
A reputable garage quoted £145 to replace the back box and middle section of (R reg) Puma exhaust.
However, on taking it in to be done they said they believed the Cat needed replacing and to replace the whole exhaust and cat would be £450.
However, another garage looked at it and said it is NOT the cat, but the engine is misfiring (on three) and it will cost either £20 or £100 to fix depending if it is the plug, plug lead or coil pack(?) which needs replacing!
Which sounds correct?
Old Nov 15, 2009 | 01:43 AM
london_chris's Avatar
london_chris
coil packs on the puma zetecs are quite common, although if the cat is blocked you will have a severe lack of power and poor running,
i would suspect the coilpack first as its cheaper, once its running right then look at the rest?
Old Nov 15, 2009 | 08:18 AM
Misfiring can kill the cat anyway, so they both might be correct, fix the misfire immediately if not sooner, then check what the emissions are before replacing the cat.
I did a cat earlier in the year on a mondy, and it was around £75 for the pipe with the cat in it all one piece.
Got it from Exhausts Unlimited.
Old Nov 15, 2009 | 08:34 AM
gary fraser's Avatar
gary fraser
dont know about £450 for the exhaust try online automotive they got the full system including cat for £245 mate only take an hour or so to do yourself
1 of 1 Exhaust SystemSY-0008124Category:ExhaustsVehicle:Ford Puma 1.7i 16v 6/1997 > 10/2000 CoupePrice:£212.98 ex VAT (£244.93 inc VAT)With fitting:£420.98 ex VAT (£484.13 inc VAT)
Old Nov 15, 2009 | 10:29 AM
Ian2861's Avatar
Ian2861
Thanks all.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
DAZZER
Sep 30, 2015 08:43 PM
youngben
Sep 27, 2015 09:37 PM
Marv888
Sep 26, 2015 03:44 PM
