can 2wd drive shafts fit onto 4x4 rear drive flanges
as above iam thinking of buying wrc / group a uprights with drive flanges etc as most are for 4x4 escorts , just wanted to know if its worth buying cause if the 2wd drive shafts dont bolt up i will look at getting something custom made,
any help would be great
cheers paul
cheers paul
2wd are 108 mm 4x4 are 100 mm.so no,you cant join them together.
you can fit the 2wd drive flanges into the 4x4 diff,and the outer flanges are changable to 2wd.that would let you use 2wd shafts.
cheers paul
cheers paul
lockie
Jul 31, 2015 10:03 PM
