Electrics
Old Nov 12, 2009 | 07:53 AM
DMR's Avatar
DMR
Default Electrics
Just a little annoying problem, first thing in the morning i unlock the car to take the missus and kids to school my door opens fine but it take between 5 40 secs for the central locking to kick and unlock the resthasen't done it at all through summer so im guessing it either the cold or damp morning dew thats causing it. also when i driving along on the odd occasion the central locking will lock all the doors for no reason, (Scares the crap out of me)
Any ideas?
Thanks
Danny
Old Nov 13, 2009 | 07:56 AM
scotty dog's Avatar
scotty dog
I think the locking while your driving bit is due to how it is setup, I sourced this info from FordST170.co.uk:
Auto Door Locking (source: Tourque Steer)
  • 1. Turn on the ignition but dont start the engine
  • 2. Lock the door by pushing in the button below the handle, and then pull the handle slightly to reopen it (Repeat this operation three times)
  • 3. Turn off the ignition
  • 4. Lock the door by pushing in the button below the handle, and then pull the handle slightly to reopen it (Repeat this operation three times)
  • 5. Turn on the ignition but dont start the engine. A beep should be heard
  • 6. Lock the door by pushing in the button below the handle and then pull the handle slightly to reopen again. A final beep should be heard and then start the engine.
Basically, once you set this up the doors will lock automatically more or less as soon as the car starts rolling, nominally @ 7kph. You'll still be able to open the doors by pulling the interior handle, but they won't be able to be opened from the outside. If you stop and open the door though they won't relock automatically unless you turn off the engine and restart - basically, it works once per journey, after that you have to do it manually. And in the event of an accident, the airbag system will unlock the doors automatically, so you don't need to worry about that aspect.
I dont know how to disable it though.
Old Nov 14, 2009 | 09:27 AM
DMR's Avatar
DMR
that did nothing but worth a try
Nov 1, 2015 06:53 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
stevecfrst1
Sep 30, 2015 05:18 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Kam B
Sep 24, 2015 10:40 AM
