personal plate removal advice !!!!
does a car have to haev a valid mot or is there a date or expiry that the mot can be in order to remove a plate off a car ???
my mot runs out end of jan but i dont think ill get it rebuilt intime to get the dvla to inspect it
i knwo the tax rule but to remove the plate does the car need a mot ???
as in couldnt ya say the car is off the road, failed mot and so i want to remove me plate plase ???
as i can get it taxed again no probs, getting a mot on a car thats never gona be running again is gonna be hard, ive gotta dummy fit a engine and box and tell em its broken down ya see
hence why im asking
also need a passenger side hub to make the poxy thing run too
hence why im asking
nope, it -has- to have an mot! I know this as when i stripped my cossie I was originally going to sell the plate seperately and as the MOT had run out I literally had to get it MOT'd the same day that it started to get stripped DOH!!!! Ł35 wasted, even more so considering I ended up selling it with the shell/logbook anyway
yeah tis a pain in the ass, I phoned DVLA to question it but they said no way without MOT and tax. Worse thing is, you dont actually own the plate either, just the rights to use the plate against the car its registered too, hence scrap the shell or sell it on and the plate goes with it
no I know hence the reason I got it MOTd the day it was being stripped, nearly lost out but had a tip off and phoned the DVLA and thats what they told me so quickly phoned gaz @ CPP who was stripping it for me and told him MOT it first! Give DVLA a call first thing in the morning and tell them your predicament, see what they say and how they can help
Well heres the deal, theirs 2, yes TWO screwes on either side on BOTH plates (usually under the lil ingenious caps!!) pop the caps off with a flat driver, then unscrew with USUALLY a philips, but may also be flat headed so be ready!!
once undone, pop off she falls, easy, same as normal plate pmsl
