9 inch jag diff
does any one no wich jag its off coz i now some one that brakes jags and siad he has lots of jag diffs that i can by next to nothing so does any one no wich 9 inc rear diff to go for and are they strate it
Ryan,
there 10.5inch diff's not 9" on big jags
to be quite honoust the cwp does vary around these figures , not quite as poxy as 9" like but 9.5" is about teh smallest for the 4hu case up to the largest one i have which is just knocking on 10.5"
ok so a 10.5 is big and a 450 bhp going side ways is that gona take it or is it for top end and how much is the diff worth as might be abel to get hold of a good few
pm brom , he will let you know what there worth to buy/sell.
i know what i pay for mine , i helped with the conversion as my car had this setup for about 5 year or more now, so its now his conversion and far be it from me to quote prices !!
mark
mark
I throught some of the xj 40 jags had 9in diffs in, the ones on the change
over period from inboard discs to the later outboard ones. the toyota supra
twin turbos also have a 9in diff, kos iv got one, there not as cheap as the
jag ones though, but are pretty indestructiable.
Ryan,
anything under 550 i would not use a jag diff, i would use a 7.5 plated item or a Quiaffe or Gripper.
personally i would use this setup at std power as even that fooks sun/planet gears in teh std units, up from that a good 400 power plant will fook a high mileage cwp , and try and find a low milage cwp these days , there arnt any.
i also recomment tom seal's gripper diffs , used thena few times , excellant kit
The toyota 9in diffs do come in different ratios, from just over 3-1 to just
over 4-1 , thers a metal tag on the diff casing relating to what the ratio
is starting with a w.... unfortunatley they dont put the actual ratio on the
tag, its just a part number so u need to do a bit of homework first.
Johnny Knoxville
Sep 30, 2015 07:21 AM
DavidK
Sep 27, 2015 02:55 PM
