Ford Puma Discuss the Ford Puma here!
Puma boiling over
Old Nov 8, 2009 | 10:12 PM
Ian2861's Avatar
Ian2861
Default Puma boiling over
Recently bought Puma 1.7 started boiling over tonight.
Filled up the water but by 6 miles later there was no water left in the tank again and steam coming out again.
What is likely to be the problem - is it serious?
Old Nov 8, 2009 | 10:45 PM
ally261's Avatar
ally261
sounds like head gasket, might be fairly serious if its been ran too hot
Old Nov 9, 2009 | 04:35 PM
If you're lucky it will be a split pipe dumping water on the exhaust, but I would have a good look, and be prepared for the dreaded HG!!
Old Nov 9, 2009 | 04:43 PM
Dal_'s Avatar
Dal_
Check the water pump as well in case that's failed and pissing water out.
Old Nov 9, 2009 | 06:03 PM
v8saff's Avatar
v8saff
if ya need a spare engine ask rstingle on here as hes got a puma just sittin on his drive
Old Nov 10, 2009 | 11:06 AM
Ian2861's Avatar
Ian2861
Thanks.
It wasn't the head gasket but some pipe that had come away under the windscreen, leaking water. Well, two pipes in the end.
Got it fixed for £80 + VAT, but a few hours later started getting problems with the exhaust (see my other thread)!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
youngben
Sep 27, 2015 09:37 PM
Marv888
Sep 26, 2015 03:44 PM
Ben26
Sep 3, 2015 07:55 PM
