buying a cossie? where to check chassis numbers
Look at all the glass!!!!!---(genuine factory glass)should all match usualy the drivers side is different if its been broken into!!,
also open the doors fully and look at thr wing behind the hinges there should be black plastic type stickers top to bottom, if not !the wing has been replaced.-i could go on but i must go--.
kosienutter
31
Aug 22, 2015 09:55 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
