Tappet sequence & gap size ohv 1300cc 2000
Old Oct 25, 2009 | 03:37 PM
Wheels In Motion's Avatar
Wheels In Motion
Default Tappet sequence & gap size ohv 1300cc 2000
Hi just bought a 1300cc fiesta ohv on a 2000 plate, Could anyone tell me the sequence and gap please for the tappets on this engine. It has a black rocker cover not the green endura one
Thanks in advance
W I M
Old Oct 25, 2009 | 03:51 PM
m4tt274's Avatar
m4tt274
it will say in the hayes manual.
on the valencia which i know is similar to the endure however i dont know if is the same.
when cylinder 4 rocking adjust cylinder 1. 3 and 2. 1 and 4. 2 and 3.
and the exhaust clearance is 22thou, inlet clearance 10thou (cold)
as far as im aware the endure is a refined EFI valencia but im not 100% sure.
Old Oct 25, 2009 | 04:14 PM
Wheels In Motion
Thanks for that i will get a hayes manual tomorrow shops shut now, Thanks for the information much appreciated
Old Oct 25, 2009 | 08:13 PM
The most sure fire quickest way is after taking the plugs out to change or clean them during service just put car in 4th and move till 1 tappet of each cylinder in turn is pressed down then adjust the other one in that cylinder.
The endura is indeed a refined version of valencia, when adjusting the rockers pull up on the rocker with your fingers at the same time as inserting the feeler gauge, these suffer terribly with wear, this way you get a true gap.
If the rocker shaft is badly worn it can be taken out spun 180 degrees and reinstalled upside down so unworn side is on bottom instead of worn side of shaft.
Old Oct 25, 2009 | 08:30 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
exhaust is 0.5mm inlet is 0.2mm
rocker cover makes no odds, they're both still endura-e engines
Old Oct 26, 2009 | 06:26 AM
Wheels In Motion
Thats top advice thanks very much, didnt realise you could spin them 180 degrees. you learn something new every day many thanks all
Old Oct 26, 2009 | 03:44 PM
Yes if you turn it looking down on it through 180 degrees, then rotate shaft looking from end through 180 it all lines up again but puts the unworn side as the load bearing side.
Obviously you have to dismantle the whole rocker gear but easy enough to do.
Make sure you keep on top of oil changes as these are not unknown to snap the rocker shafts, normally between 3/4 knocking cylinder 4 out, but it's always due to bad looking after.
Old Oct 26, 2009 | 06:43 PM
Wheels In Motion
Cheers for all your help tabetha, I will have a go at the tappets this weekend it sounds like only a couple of them are rattling. I had an earlier fiesta some years ago and they were adjusted by the rule of nine, why did they have to change it lol. I plan on doing oil & filter changes every 6000 miles think thats a good time. Regards W I M
boeb
Jan 9, 2020 05:11 AM
gambo08
Feb 4, 2016 10:49 PM
Nov 1, 2015 06:53 PM
little bram
Sep 27, 2015 07:45 AM
