IK31's and cold starting?
Old Oct 21, 2009 | 06:36 PM
Paul_RS's Avatar
Paul_RS
Default IK31's and cold starting?
Will these plugs make a coilpacked cossie harder to start from cold? Ever since fitting them mines been a right pig to get going! Its very hard to start now
Seemed fine on my old NGK9 plugs? Only difference is the IK31's are gapped wider for the coilpack conversion...
Old Oct 21, 2009 | 10:00 PM
Try closing the gaps down, but no won't make it harder to start as they require less current than most plugs, they do foul relatively easy though.
Old Oct 22, 2009 | 12:37 PM
Paul_RS's Avatar
Paul_RS
Closing the gaps kind of defeats the whole purpose of fitting wasted spark though? I've gapped mine to the msd specs?
Old Oct 22, 2009 | 04:24 PM
Really, the point of coilpack is NOTHING to do with larger gaps.
Larger gaps came about with lean burn technology where ever leaner mixtures needed fatter sparks for best performance.
Coilpacks came about due to natural progress, reliability and COST nothing more.
Old Oct 22, 2009 | 05:36 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Iridium, pish...why spend Ł40 or whatever on a set of plugs when a set of NGK BCR 8ES plugs ar a tenner, and better?
Old Oct 22, 2009 | 05:46 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
......and how long do they last...???......u change 071's every service (4kish)........iridiums last 20k+
Old Oct 22, 2009 | 05:56 PM
Paul_RS's Avatar
Paul_RS
I'll try smaller gaps and see what happens
Old Oct 22, 2009 | 06:04 PM
pete mcrash
...so what gap are u running....???.....mine's at .75mm (grp A coil)......and u wont see any benifit from going larger......
Old Oct 22, 2009 | 07:36 PM
Paul_RS's Avatar
Paul_RS
Its whatever MSD recommend? I just follwed the instructions that came with the kit lol. Think it may be .75mm as well actually?
Old Oct 22, 2009 | 10:13 PM
vroooom ptssssh
It Wasnt Me!
071c's are crap too!
Iridiums just dont seem to last as well as the NGK's, saw many cosworths with a miss-fire use them, swap to NGK's and back to normal...
but if your happy with them then carry on this is just what i've experienced.
Old Oct 22, 2009 | 10:29 PM
pete mcrash
.....................i use NGK iridiums..............
Old Oct 22, 2009 | 10:31 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
the biggest killer of iridium plugs, or any plug imo is incorrectly fitting them,
i see incorrectly fitted plugs every day lol.
if correctly fitted the denso iridium plug is very very good
simple 071cs are also a good cheap option, we use them to over 500 bhp, and they are seriously cheap these days
Old Oct 22, 2009 | 10:45 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
How do you incorrectly fit a spark plug? Apart from the gap and heat range?
Old Oct 22, 2009 | 10:46 PM
JTECH James
Passion for Fords!
quite a few ways!
Old Oct 22, 2009 | 10:47 PM
JTECH James
Passion for Fords!
do any of you use an anti seize compound on the thread? like copper grease?
Old Oct 22, 2009 | 10:48 PM
RWD_cossie_wil
Serious question, in what ways?
Old Oct 22, 2009 | 10:50 PM
JTECH James
Passion for Fords!
will?
Old Oct 22, 2009 | 11:28 PM
Rax's Avatar
Rax
I use IK31's in my car with a group A coil.It did have these fitted when I got it,the only problem I had was a slight misfire in 3rd coming on boost.It only happened the once so I fitted a new set gapped at I think .75.The car gets used everyday and has covered over ten thousand miles on this set without a hicup.It maybe due a new set now though,but there has never been any starting problems.
I have just realised that I am a big fat billy liar,I have ngk bkr9eix gapped at .65 or so my note pad informs me.I have to write everything down because I forget everything.
Old Oct 23, 2009 | 12:07 AM
RWD_cossie_wil
No mate
Old Oct 23, 2009 | 12:19 AM
SS1's Avatar
SS1
iirc the plugs dont need gapping ..just fit them as above
but the copper slip and silicone grease comes to mind
Old Oct 23, 2009 | 01:06 AM
Rax's Avatar
Rax
Why would you not gap them or at least check.
Every plug I buy for my bike has to be gapped and the same goes for my car.None of them come ready gapped like you would think they would.
Old Oct 23, 2009 | 01:53 AM
SS1's Avatar
SS1
I did change the gap "then asked the old owner of my car " lol
The densos can be damaged very easy changing the gap on them
i always check that type of thing before its fitted to the car
He said you dont need to change the gaps just fit and forget
every days a skool day
Old Oct 23, 2009 | 05:26 AM
Stu @ M Developments's Avatar
PassionFords Creator
James is correct. Most Denso Iridiums are damaged by incorrect fitment. They are an excellent plug and will last tens of thousands of miles in correct use. They are also pre-gapped at 0.7mm which is absolutely ideal for wasted spark conversions as luck would have it.
The ONLY negative the Iridiums have is the ultra fine 0.4mm electrode is easily shorted by excess rich mixtures so they arent the best choice for a car that does a lot of cold starts only. IE: One in storage etc...
Old Oct 23, 2009 | 09:00 AM
RWD_cossie_wil
What would be incorrect fitment Stu? This could be a good learning thread
Old Oct 23, 2009 | 09:50 AM
First and most common is people levering on the brittle Iridium electrode to gap them. this is BAD and can cause you to lose the end in use.
Second most common is over tightening. You would have to look at a cross sectional view of the Iridium plugs to understand that even slight overtightening can crack the ceramic core insulator. This results in one of two things:
1) The center insulation material breaks away in use.
This can destroy the engine if your unlucky.
2) The cooling efficiency is badly affected, resulting in plug overheating. End result can be detonation or mechanical plug failure.
The plugs have a very specific tightening torque and going past this almost always damages them. If your unsure, have someone else fit them.
Finally, a lot of old school mechanics grease the threads of the plug and this has an effect on the plugs cooling ability. The cooling efficiency is badly affected, resulting in plug overheating.
There are other minor things , but those are the ones we see here every single week. There are way too many people out there who think they know what they are doing but cant even install a set of spark plugs correctly.
Old Oct 23, 2009 | 05:31 PM
RWD_cossie_wil
Interesting reading Stu
What torque values would you use, do the plugs (never used iridiums) have the settings on the box/destructions ? Or would you use the OE engine torque figures?
Old Oct 23, 2009 | 06:22 PM
Paul_RS's Avatar
Paul_RS
Just to add to this thread, tried my old NGK 9 plugs back in that are gapped to .5mm and the car starts way easier
I'll try lowering the Denso gap to .7 and see how that goes
I didn't grease the threads of the plug or anything, but i will admit i didn't torque them in, just give them a nip up
Apart from this one issue i'd like to add i feel the wasted spark conversion is worth every penny! Car deffo feels a lot smoother than before, especially coming on boost
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
gingeRS
Sep 4, 2015 06:29 PM
