After market speed sensor kit?
Does anyone know if anyone does a after market speed sensor kit that I could fit to my 3 Door?
Cheers Rich
Cheers Rich
I need something the works along side with the manual worm drive in the gearbox, say something that works off a drive shaft or wheel.
Cheers Rich
Cheers Rich
Is it just so you can disconnect your speedo and not put anymore miles on your car?
If so, try a GPS based heads up display, ive got one for my car (no speed sender in the box cause its too modern!) and its great
They will pick off any metal target, usually a multi toothed wheel of some sort or as jon says wheel/brake studs...
We have 5 on the escort, 2 in the gearbox, one on each front drive shaft and a seperate 1 for the trip meter....
spec sheet below:
spec sheet below:
Rich,
Good site for information on speed sensors.....
http://www.dataspares.com/acatalog/W...d_Sensors.html
The last one on the page is the GT1.....
Pics of them fitted up on the car...and some brackets....
There is a ring for sensors at each corner of the car, these can also be linked into sometimes, TVR use a very sophisticated mr sensor on the diff on certain models with a toothed bolted to the driveshaft/diff output flange.
DixieTheKid
11
Jun 6, 2020 11:20 AM
jonfoc
16
Sep 11, 2018 05:35 PM
mike elsome
Sep 14, 2015 04:08 PM
Si B
Sep 12, 2015 06:49 AM
