Removing nut from GAZ coilover
Old Oct 19, 2009 | 06:48 AM
S2_RST_DK's Avatar
S2_RST_DK
Default Removing nut from GAZ coilover
The nut at the top of my coilover at the rear has been tighten to much by the mechanic.
I have tried to untighten the nut but it is stuck, and know i can see that the spanner is begining to damage the top.
How do i remove the nut without putting more damage the top of the shock ????
The picture is from before i tried to remove the nut, so the top is looking ok here
Old Oct 19, 2009 | 07:28 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Are you holding the other nut with a spanner to prevent the shock from turning?
Are you doing it with the wheels on the ground?
Are you using a spanner with a steep offset head, so that it engages on the nut properly?
Old Oct 19, 2009 | 11:33 AM
NUTS RuS's Avatar
NUTS RuS
If you can use an air tool gun with a deep socket it will spin it off ok
Old Oct 19, 2009 | 12:13 PM
S2_RST_DK's Avatar
S2_RST_DK
Christian: thats a yes for all 3 questions... should the car be lifted ??? (I actually bought a set of spanners with steep offset head, thinking i could fix this problem easy )
NUTS RuS: i havent got air tools, but talked to an old mechanic who said the same thing, apperently not an uncommon problem
I quess i better find someone with air tools an a deep socket...
Old Oct 19, 2009 | 06:32 PM
Alvyn's Avatar
Alvyn
just drive it to a local garage and they will air gun it off for you I'm sure!
yatta
May 21, 2016 10:31 PM
cossie330
Oct 7, 2015 08:22 PM
CrOwSoN15
Sep 24, 2015 01:36 PM
Fudgey
Sep 17, 2015 01:06 PM
