Corsa C gearchange adjust
Old Oct 17, 2009 | 07:53 PM
Default Corsa C gearchange adjust
Help mates daughter's car won't go into 1st or 2nd at all really, well does occasionally if forced.
Clutch is 100% perfect as is box once in, clearly it's a adjustment problem, but don't know how to do this on these, they don't have a manual, mates going to do it himself whilst I laugh, I mean watch, jesus the oil check is like rocket science to him!!
I want to keep on the good side of his(absolutely gorgeous) daughter!!
Thanks, for any help, though I can manage the daughter on my own!!
Moron from local garage diagnosed over the phone, a new gearbox and clutch!!
Old Oct 17, 2009 | 07:55 PM
saph4be's Avatar
saph4be
there a little rod you can push in on top or gear box to lock box in position and then remove gaitor around gear stick and you will see two holes which you drop a pin through and then tighten linkage sorry can't be more helpfull been a while since i done one mate
Old Oct 17, 2009 | 07:58 PM
washy's Avatar
washy
this happened to the mother in laws corsa c. it was the gear linkage thing. its made of plastic and they snap easily. Someone will be ableto explain it better than me im sure!
Old Oct 17, 2009 | 08:01 PM
saph4be's Avatar
saph4be
this is correct the linkage is prone to wear easy to change and not too expensive
Old Oct 17, 2009 | 08:22 PM
WOT's Avatar
WOT
hi, vauxhall do a modified linkage for this problem, although i would try resetting the adjustment first before you replace it as this can cure it temporarily. to do this 1st lift up the gearstick gaitor you'll see a small hole in the left hand side of the housing and also one on the gear stick, line these up and use a 3/16 punch or drill bit to lock them in place. next on top of the gearbox, the selector turrett has a small plastic spring loaded plunger. see if you can press this in until the spring is fully compressed. if you can then you'll need to change the linkage as theres too much play in it. if you cant press it in all the way then get underneath the car and slacken off the bolt on the gear selector rod, then back on top, wiggle the plastic UJ by the selector turrett until you can get the plunger all the way in. then tighten the bolt, remove the punch.
hope that helped
Old Oct 17, 2009 | 08:25 PM
saph4be's Avatar
saph4be
hope that helped
what i was saying but worded better
Old Oct 17, 2009 | 08:37 PM
murfs frst's Avatar
murfs frst
common fault on them,new linkage unit should sort it
Old Oct 17, 2009 | 08:45 PM
Thanks peeps, much appreciated, maybe I'l get a reward!!!!
Old Oct 17, 2009 | 08:54 PM
saph4be's Avatar
saph4be
which you need to share
Old Oct 17, 2009 | 10:25 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
I had exactly the same issue with a corsa c a couple of days ago. Just farted around with the linkage until I got the gears spot on, unfortunately I didn't know about the pin hole under the gearlever gaiter! LOL!
Just undo the torx bolt on the linkage rather than try to undo the nut on top! The nuts welded to the linkage! Looks just like an ordinary nut when you look at it from the top! Thought it was tight! LOL!
Old Oct 17, 2009 | 10:27 PM
RONNIE AMIS's Avatar
RONNIE AMIS
as everybody has said it is a common problem on them, one of the plastic knuckles wear
Old Oct 18, 2009 | 12:05 AM
mechanic28's Avatar
mechanic28
As above very easy job to do!pm m,e if you need any help bud
Old Oct 18, 2009 | 07:51 PM
Thanks for the advice, hopefully I will get a good service out of it, so long as the gf doesn't see this thread, otherwise it's back to the nasty hospital food!!
yatta
May 21, 2016 10:31 PM
mk1turboestate
Dec 2, 2015 08:31 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
coscor86
Sep 20, 2015 01:21 PM
