mk6 van ghia upgrade
Old Oct 17, 2009 | 07:35 PM
rs2300 van's Avatar
rs2300 van
Default mk6 van ghia upgrade
hi i have a escort van on a v reg and want to up grade the the top luxoreys p/a/s, c/l, e/m, e/w, aircon, heated front screen and washers and electric seats etc.
what loom would i need to use or do all the extras i want to fit just clip into the loom i have already or do i have to build a loom with all the extra parts myself.
also doing a 2.3 rs2000 converstion at same time cheers
Old Oct 27, 2009 | 11:26 AM
Omawarisan's Avatar
Omawarisan
I am looking at doing an RS2000 Conversion on my van which will cover alot of what you are looking to do. You would need an RS2000 wiring loom and ecu with the only modification being splicing in the rear clusters. Everything else is plug and play pretty much. Not sure about the heated screen and electric seats though as I don't think these were standard on the RS2000. It is a fairly straightforward job. Regards. Chris
tankybaby66
Feb 6, 2016 02:24 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
AJC
Oct 1, 2015 06:47 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Sp3no
Sep 27, 2015 07:23 PM
