could some one help
Old Dec 25, 2004 | 08:20 PM
abdr500's Avatar
abdr500
Default could some one help
the torque settings on a cosworth head bolts is it 20 nm 40 nm and 2 90 turn or am i incorect
Old Dec 26, 2004 | 11:49 PM
capri-rs's Avatar
capri-rs
on 2wd
Stage 1 20-25 nm
Stage 2 45-50 nm
stage 3 rotate further 170 -180 degrees
On 4wd
stage 1 45-50 nm
stage 2 turn 180 degrees +/0 10 degrees
stage 3 check for 110 nm
this should be with lightly oiled threads
according too manual
hope this helps
Old Dec 27, 2004 | 03:36 PM
abdr500's Avatar
abdr500
thanks
