LHD question - rear window switches
Old Oct 17, 2009 | 06:49 AM
pacwest's Avatar
pacwest
Puller of the Wrench
Default LHD question - rear window switches
My 88 saff has wind up rear windows. It's continental and LHD.
Behind the handbrake storage compartment there are two holes for rear power switches but they are vacant. I'm guessing Ford didn't bother with a simple cover for these correct?
Old Oct 17, 2009 | 02:54 PM
That's where the rear switches are yes, plus the front switch panel has all four window switches in it, and a button in centre to turn off the rear window switches.
Old Oct 17, 2009 | 03:15 PM
pacwest's Avatar
pacwest
Yep, my center panel only has two switches. No lockout. Wired only for two just like a 3 door.
A bit shabby on Ford's behalf to just leave the rear switch holes bare. Anyone know of a donor car that can supply a neat filler/blank?
Old Oct 17, 2009 | 03:28 PM
Why not make them leccy in the rear ?
Don't know of any blanking plugs, maybe they were never fitted, but worth checking to see if ford still do any ?
Old Oct 17, 2009 | 05:51 PM
cozzfather's Avatar
cozzfather
C.R.E.A.M.
all the lhd sierra cosworths i had were slightly different specs than the uk models.
my 3dr cosworth had manual windows instead of electric,the 4dr sierras all had no rear ew
Old Oct 18, 2009 | 08:55 AM
Iain Mac's Avatar
Iain Mac
I'm working from memory here so may be wrong, but I believe that Ford used a single consol armrest for cars with electric or manual rear windows.
The cut-outs were marked on the inside and it sounds like yours has come from a car that had electric rear windows - I don't think there were any blanking plates used there because there were no holes on cars that didn't need them.
Your best bet would be to either pop switches in, convert to rear electric windows, or check out other blanks from, for instance, heated seats, boot release, other models/makes to find some that fit. If necessary, you could open up the holes a wee bit until they fit.
3dr cossie
21
Nov 20, 2015 05:00 PM
3drRich
Sep 13, 2015 07:32 PM
clay26
Aug 31, 2015 01:10 PM
borboyous
Aug 22, 2015 11:17 AM
liam-rst
Aug 10, 2015 08:46 AM
