More valve lift on an Endura?
Old Oct 15, 2009 | 07:38 PM
RedLexus's Avatar
RedLexus
Default More valve lift on an Endura?
Looking for advice all , trying to increase the bhp of the rally KA , are there higher ratio rockers on the market , or whats the ultimate cam for rally use for a 1300 Endura? Thanks.
Old Oct 15, 2009 | 08:05 PM
You can't just go and increase lift, unless you know for a fact there is adequate valve/piston clearance, but a call to piper or kent should help.
Old Oct 16, 2009 | 08:14 AM
RedLexus's Avatar
RedLexus
I have clearance , just couldn't find anyh=thing on their sites apart from Cams themselves .
Old Oct 16, 2009 | 08:50 AM
I would phone them, they can always do a one off grind, they're not much dearer than std off the shelf ones either.
Old Oct 16, 2009 | 10:33 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
as above, contact kent/pipe or even newman and get a better cam.
different ration rockers can only work if the fulcrum is moved, and that would be very expensive to do.
Old Oct 16, 2009 | 11:40 AM
If you do phone Newman ask for KEN, not dave.
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
IainRS1700T
Sep 25, 2015 06:44 AM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
