Fuel pump + Tank
Old Oct 15, 2009 | 02:17 PM
AstoN_B's Avatar
AstoN_B
An eye for detail...
Default Fuel pump + Tank
For a 1.8 zetec turbo, what size/make/where can i find the right pump? Off the top of my head, i estimate about 180bhp, with 130spec cams and emerald k3 with T25 turbo, unsure which injectors are needed yet. Will get more involved with that when i'm halfway through body prep and bought the engine.
Is 1.8 zetec escort GTI the best engine for conversion into mk4 cab? Heard it's slightly different...
And am i right that a mk4 3i tank is ok since it has swirlpot built in and designed for external pump?
Any help appreciated, thanks in advance
Old Oct 16, 2009 | 09:36 AM
AstoN_B's Avatar
AstoN_B
would a Bosch 3.4ltr/min @ 3bar pump be enough? And would it use original ford electrical connections or would i need to put new ones on? (no problem since the loom is out anyway.)
Old Oct 16, 2009 | 05:09 PM
AstoN_B's Avatar
AstoN_B
evening bump
Old Oct 16, 2009 | 05:40 PM
If using a external pump, just use the std xr4i/cossie pump the 941, about £70, will supply well over 350 bhp, also depending on what rail you are using, if you use top feed injectors, instead of side feed zetec ones you could pick up a set of std yellow injectors for around £40.
Any injection tank will be fine, external pump one.
The 941 bosch pump has the common post connector, that the plug goes onto/over, the uprated 044 pump(not needed for you) has screw terminals, so most put on a ring terminal on there.
Old Oct 16, 2009 | 05:42 PM
botters's Avatar
botters
competant bodger
as above and rs turbo tank or xr3i tank should do
Old Oct 17, 2009 | 05:13 PM
AstoN_B's Avatar
AstoN_B
Thanks for the response guys, i plan to use rover inlet so not sure on rail yet. 180bhp'ish was my estimate, dont need much more. whichever way is cheapest to get that.
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
15
Oct 7, 2015 03:43 PM
dirtysteve
Ford Focus ST
Sep 16, 2015 05:29 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
