6 Ton Press
Old Oct 14, 2009 | 04:00 PM
gatekiller's Avatar
gatekiller
Stephen Hill
Default 6 Ton Press
Looking at buying a press for things like wheel bearings, bushes etc and was wondering if a 6 Ton press will be enough?
Eg: http://cgi.ebay.co.uk/6-Ton-Industri...QQcmdZViewItem
Ste
Old Oct 14, 2009 | 07:00 PM
Easily enough, not needed though, can be done without, I haven't needed a press in over 25 years for these.
Old Oct 14, 2009 | 07:59 PM
gatekiller's Avatar
gatekiller
Stephen Hill
Sweet.
I know I could do it with a threaded bar and some large washers but a press would be useful for other stuff too and I like to have big toys in the garage
Ste
Old Oct 14, 2009 | 08:02 PM
.Ross.'s Avatar
.Ross.
Press looks ok .. Light duty if anything ..
You can always replace the Jack with different rams .. Find out what MAX rating the bench is good for.
Old Oct 14, 2009 | 08:09 PM
fraser9764's Avatar
fraser9764
just buy a 10 tonne bottle jack, which are sub Ł20 and usefull for other jobs, and bolt together a very sturdy frame. Im going to build one with 2 lengths of 4" U section Chanel and some hefty threaded bar so it is height adustable.
Old Oct 14, 2009 | 08:15 PM
gatekiller's Avatar
gatekiller
Stephen Hill
I'll probably buy the 6ton and then upgrade the bottle jack at some point in the future if required.
I only really need it for bearing and bushes.
Cheers Guys
Ste
Old Oct 14, 2009 | 11:04 PM
NUTS RuS's Avatar
NUTS RuS
I have a Sealey one in stock - will look what it is tomorrow
(Think its 10T)
Some of the bushes on modern Ford and Vauxhall rear axles are becoming a pain without one now.
Old Oct 14, 2009 | 11:35 PM
turboRS's Avatar
turboRS
C16OSY
iv had stuff that wont budge at 50 tonnes
IMO go for atleast a 30 tonne press.
Old Oct 14, 2009 | 11:46 PM
NUTS RuS's Avatar
NUTS RuS
Agree on some of the newer wishbones etc as we struggle like mad to get brand new ones out to replace them with alloy spherical bearings on things like Mk6 Fiestas etc. Some of them are pressed in under immense load
But for wheel bearings canabis resin and rusty bushes etc a smaller one will get you up and running. Im sure thats where some that sell end up lol
gatekiller's Avatar
gatekiller
Stephen Hill
Hmmm, getting a few mixed messages now...
Some saying a 6ton should do for the odd wheel bearing and others are saying a 10+ is required minimum, maybe even a 30!
Now I'm confused
I would have thought anything over 20ton would start to bend the races?
Ste
Old Oct 14, 2009 | 11:48 PM
gatekiller's Avatar
gatekiller
Stephen Hill
Yikes. I own MK6 Fiesta
Old Oct 15, 2009 | 09:40 AM
gatekiller's Avatar
gatekiller
Stephen Hill
(Think its 10T)
Hi Mate,
Do you have that press in stock?
Ste
Old Oct 15, 2009 | 10:09 AM
NUTS RuS's Avatar
NUTS RuS
Yes its a 10T one similar to this (ie proper hydraulic ram etc)
http://www.machinemart.co.uk/shop/pr...raulic-presses
Ł185 delivered
So not sure if its more than you wanted to pay, but to do some of the jobs you do need a decent pressure one.
tony
Old Oct 23, 2009 | 09:57 AM
Jamie@FastFord's Avatar
Jamie@FastFord
Jamie @ Fast Ford
I've got the 12tonne version of the same press you're looking, even bought from the same people (KMS)
It's perfect for wheel bearings/bushes etc. IMO go for the 12tonne as its only a few quid extra iirc.
A.t.p
Sep 29, 2015 05:04 PM
Rsmat
63
Sep 25, 2015 12:11 PM
Fudgey
Sep 17, 2015 01:06 PM
The Enigma
Sep 12, 2015 10:12 PM
hopper350
Sep 4, 2015 12:53 AM
