£800 to change an engine??
ello,
in the process of fitting a 1.8 xr2 engine into my mk 3.5 fiesta,
everything is there to bolt it, engine, gearbox, loom, ecu....
im no expert but thought this wouldn't be a big job (for someone who knows what there doing)
had 2 quotes now, first was £400... but the geezer didn't have a clue, the second was £800!
is this right?
is this right?
a day = 8hrs and i doubt its sufficient....multiply that by 80 quid/hr (and thats cheap) and ur @ 640 £ then add some fluids and unforseen stuff and VAT.....voilà @ 800 £
the 400£ offer is by someone who doesnt even own every size spanner needed....
im not having a laugh, no.
i tend to bring my cars to good places and thats what they cost. if you want some moron who cant tell his ass from his elbow work on your car then go ahead.....
any know of somebody in west yorks?
if you new anything bout spannering
your best bet it try a few places ,west yorks place in bolton they are good big goeff
Hire an engine hoist for a couple of days and do it yourself. Its more satisfying too, once its in and you get it running.
Either that or find some one local who works on cars, no way would i pay 400 quid for an engine removal/fitment.
Good luck.
Good luck.
considered that.. i have a hoist already.... wouldn't know where to start lol
i'll do it for £400 drive in drive out.
I just charged someone off here £450 to build an engine inc spraying all bits, swap engines over, fit front mount inc trimming bumper and fit / wire up a cossie management conversion! - think i under charged
If you have a hoist like the others said then most of the work can be done in little under a few hours.
The MK3.5 had this engine in it aswell so its not complicated. Put the engine and gearbox together and put it in from the bottom. On the loom all the plugs are different from each other so its easy to know here they go and the water plumbing won't take you long either.
The first quote you got sounds more realistic from any normal garage that isn't BMW or Aston Martin....
Its a simple job that any decent back street garage can do just fine, it doesnt need an expensive speciliast, especially given that NO garage will give any sort of guarentee as he is supplying the engine.
Its all relative, no point paying 800 pound to fit a 200 pound engine!
Ben26
Aug 27, 2015 08:56 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
ekjim
Aug 17, 2015 08:57 PM
