Will these fit?
Old Oct 12, 2009 | 10:59 PM
white2lsr's Avatar
white2lsr
Default Will these fit?
Can anyone advise me as to whether I will have problems fitting these wheels with them being 8" wide?
CLICKY
Old Oct 13, 2009 | 07:35 AM
jonny s2's Avatar
jonny s2
CLICKY
yes they will fit adam,but you will have the same rubbing issues as escort cossie wheels,would look mean though and totally different
Old Oct 13, 2009 | 09:06 AM
white2lsr's Avatar
white2lsr
With being ET25 am i right in thinking they will sit further into the arches than the escos wheels?
Old Oct 13, 2009 | 04:27 PM
THEDMAN's Avatar
THEDMAN
Here is mine with 8x17 ET33
8x16 ET25 (Escos Monte)
Old Oct 13, 2009 | 04:35 PM
jonny s2's Avatar
jonny s2
they should sit exactly as escos wheels as they are et25 also
Old Oct 13, 2009 | 04:50 PM
THEDMAN's Avatar
THEDMAN
Old Oct 13, 2009 | 06:05 PM
muz's Avatar
muz
Wye Valley Hardcore
ET25 wheels will need 8-10mm spacers to bring them back to a useable offset. I'm running 8x17 ET35 wheels on mine and have slight rubbing on the rears but with a little trimming they'll be ok.
Old Oct 13, 2009 | 06:45 PM
JohnnyBgood's Avatar
JohnnyBgood
Virgin, Its true!!
Wrong way round mate. If you put 10mm spacers on a et25 it would bring them out to et15 not et35! So they would stick out and scuff like a bitch
PS The smaller the offset the further the wheel sits out.
Old Oct 13, 2009 | 07:27 PM
muz's Avatar
muz
Wye Valley Hardcore
oh yeah .... Ignore me
Old Oct 13, 2009 | 09:07 PM
Rob_DOHC's Avatar
Rob_DOHC
I have standard 2wd cosworth alloys on mine, you can't use escort bolts as they will pull through, speedshack sell the conversion bolts (and longer ones too) with the std cosworth alloys (205's) I'm having to use 6mm spacers on the back and 5mm on the front, but thats quite low on coilovers on the front. No scrubbing at all, but would rather not have the spacers!
Old Oct 14, 2009 | 05:54 AM
jonny s2's Avatar
jonny s2
pics of yours please,
Old Oct 14, 2009 | 06:02 AM
jonny s2's Avatar
jonny s2
they will fit but,you will need to trim the arches accordingly they will also stick out a little and may tram line abit,if you wanta nice ride stick as close to the standard offset as possible
Kyle Langford
27
Aug 5, 2019 07:54 PM
ekjim
Aug 27, 2015 05:20 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
marky_g
Aug 15, 2015 10:43 AM
track.focus'd
Aug 12, 2015 05:53 PM
