Brake pedal travel problem
Old Oct 12, 2009 | 09:14 PM
Gravel's Avatar
Gravel
Default Brake pedal travel problem
Hello Gentleman,
I have an issue with brake pedal travel with a tarox 6 pot system. Essentially I am getting flex someplace but cannot find it. Driving the car is normal, but once you hit a couple of corners hard, the pedal will travel an extra 30mm then firm back up again. I have replaced wheel bearings and cannot get any noticeable play when shaking down the front wheels. I drive 2 other cars with identical brake systems and neither of them do this.
This car has had the problem since we brought it over.
Any ideas?
Oh yeah, and thanks for a great resource!!! Not much information available on this side of the pond. I have been working on these things since 1997 and was quite happy to recently find this place!!
Old Oct 15, 2009 | 07:22 AM
First thing to do is seperate each corner by clamping off in turn and trying pedal, this will narrow down the affected area.
Old Oct 15, 2009 | 03:15 PM
Gravel's Avatar
Gravel
Thank you for your response. The thought has passed my mind, only problem there is that the car has hard braided brake lines all the way around. I even considered switching back to the OE Rubber brake lines for testing, but was not able to find any of the old ones in my stash of goodies. I think its time to go take a few hard corners, then limp back to the rack without applying brakes... I could then take pad travel measurements. Could be fun!
Old Oct 15, 2009 | 05:30 PM
grcossie's Avatar
grcossie
Have you new brake fluid, cold it be air in the brake system? It could be master cylinder leaking innside.
Old Oct 15, 2009 | 05:55 PM
Gravel's Avatar
Gravel
Fully flushed with Ate Super Blue. I keep up on it as far as that goes, it has been flushed a few times without any change.
Old Oct 15, 2009 | 06:04 PM
grcossie's Avatar
grcossie
Oki, if you push hard on the pedal when you not driving whit ignition on, does the pedal sink slowly, or does it hold pressure ?
Nice car, more pictures please
Old Oct 15, 2009 | 07:57 PM
Just disconnect each line in turn and plug the pipe with a brake pipe fitting welded up closed.
Old Oct 21, 2009 | 06:45 PM
Touring Car Spares's Avatar
Touring Car Spares
Originally Posted by Gravel
Hello Gentleman,
Any ideas?
you are describing "Pad knock off " ,this generally occurs when the flex in the upright/bearing etc..pushes the pistons back in the caliper , i take it you aren't using a floating brake disc/bell combination as this normally reduces what you describe .
Old Oct 22, 2009 | 03:13 PM
Gravel's Avatar
Gravel
I also believe its "pad knock off" but have been unable to find the source of the flex. You are right, no floating parts here. My perplexity here is that I have 2 other cars with the exact same brake setup and neither of them do this at all.
Definitely not exhibiting any characteristics of a failing master cylinder.
It's the run up to SEMA right now and I have not had a chance to work on the Cossie, too busy with a few builds for the show. Talk about a brake setup, I am putting a 15" front and REAR setup on a car right now! As soon as get back, I am going to dig deeper in to this one.
Thanks for your help!
And here is another picture.
yatta
May 21, 2016 10:31 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
liam-rst
Was It You?
Sep 5, 2015 06:38 AM
hopper350
Sep 4, 2015 12:53 AM
cossirob
Sep 3, 2015 09:17 PM
