Fiesta Losing Water????
Old Oct 12, 2009 | 06:13 PM
Shep_Cobain's Avatar
Shep_Cobain
Default Fiesta Losing Water????
Basically my fiesta RS Turbo doesnt overheat or anything but the header tank is always empty after a journey.
If i undo the cap slightly when warm the water does bubble up so i no its completely escaping.
I have just filled coolant up to the max mark. Drove to my mates and took him out for about 30 mins ish. After the car has stopped and cooled the header tank is empty again....?
any ideas.
The oil cap has no mayo in it etc.
Old Oct 12, 2009 | 06:55 PM
Alvyn's Avatar
Alvyn
for it to lose that amount of water without a visable leak I'd say it's head/head gasket related!
Old Oct 12, 2009 | 07:33 PM
Shep_Cobain
Hmmm really? Wouldn't it be overheating or water in the oil etc? The heaters don't get warm either. They just get about 4 degrees if that. And thts if I set the speed to 1.
any ideas?
Old Oct 12, 2009 | 09:00 PM
Shep_Cobain
wouldnt it be smoking if it was headgasket failure?
its just been to MSD 3 days ago. Wouldnt they have noticed it. They said theres a small water leak at the front of the engine.
Old Oct 12, 2009 | 09:08 PM
orionmojo's Avatar
orionmojo
You definatly need to check the headgasket. if its only a small "hole" in it, the water will be evaporated out of the exhaust and theres no way you'l notice it.
i had one go on the motorway, it was using abit of water beforehand, but not enough to worry me... i should've known.
Old Oct 12, 2009 | 09:14 PM
Robs Frst's Avatar
Robs Frst
Sounds like your headgasket is on it's way out mine was doing the same thing, mine never smoked, or had oil mix with water till it eventually let go while coming on boost.
Old Oct 12, 2009 | 09:17 PM
Shep_Cobain
How much does it cost to sort it???
Old Oct 12, 2009 | 09:20 PM
andy130's Avatar
andy130
sounds like head gasket mate but check the water pipes on the turbo incase the cracked ect
Old Oct 13, 2009 | 12:04 AM
Robs Frst's Avatar
Robs Frst
use standard ford/payen gasket, new standard headbolts will be ok.
Service items etc
Head will need inspecting, skimming head.
Shouldnt cost to much if your good with tools.
Old Oct 13, 2009 | 12:12 AM
johnandhissaffy's Avatar
johnandhissaffy
white fords look best
iv just had the same problem mine was head gasket get a tester on it and it will tell you fella
Old Oct 13, 2009 | 07:07 AM
Shep_Cobain
hmmmm.... you mean you can actually get something that tests to see if the headgasket is gone or get some one to test it?
Old Oct 13, 2009 | 07:24 AM
Shep_Cobain
UPDATED:
Last night i filled the expansion tank all the way, well just over the max line.
Checked this morning and empty.... no visible leaks though and the car hasnt been started.
Old Oct 13, 2009 | 07:58 AM
Robs Frst's Avatar
Robs Frst
Yes a fluid tester, I actually tested mine and it showed it was ok 2 weeks later my Hg went
Old Oct 13, 2009 | 09:52 AM
Alvyn's Avatar
Alvyn
UPDATED:
check the carpet as then ONLY place left its leaking from the heater matrix or pipes!
Old Oct 13, 2009 | 10:05 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
heater matrices are known for going, switch ignition on and turn demister fans on, check for water being spat out inside the car.
Old Oct 13, 2009 | 12:32 PM
johnandhissaffy
the tester is only a tube with die in it if there is carbon dioxide coming out of your header tank then the die will turn a yellow color or change color then you have fooked your head gasket
sorry about spelling
cheers johnandhissaffy
Old Oct 13, 2009 | 06:49 PM
Thats what I'd be looking at next^^
Old Oct 17, 2009 | 01:37 PM
Shep_Cobain
right found the leak!
Its coming from the rear of the head, underneath inlet manifold area rusty/brown water is spraying from that general area.
Will try and get a picture if i can....
Old Oct 17, 2009 | 04:05 PM
HG it is then ?
Old Oct 17, 2009 | 04:31 PM
Shep_Cobain
well if its spraying out water does that mean its the headgasket?
Old Oct 17, 2009 | 04:57 PM
XRdodgybird's Avatar
XRdodgybird
Praise the XR!
I was told over two years ago that because my heater wasnt getting overly warm and the car was losing a bit of water that my head gasket was probably on its way out..... 20k later and we are still on the same head gasket, the heater gets a little warmer as the car's now in daily use, but when I put the heater blowers on full, it cools down again. It still loses a bit of water but I aint worrying.
Old Oct 17, 2009 | 05:13 PM
Shep_Cobain
I cant see it being headgasket to be honest but im going to ask my local mechanic to give it a look over to be safe
Old Oct 17, 2009 | 05:42 PM
It doesn't mean automatically it's the HG, need to see precisely where it's coming from, could just be a bad pipe near the back, hopefully.
Crap heaters are due to dicky stats normally, or blocked matrix, etc NOT duff HG, just see how hot the pipes are to hold, they should be painful to hold due to heat.
Old Oct 17, 2009 | 05:44 PM
Shep_Cobain
yeh they are really warm the pipes.
Just want to say thanks for all the support guys Don't know what id do without you lot
Old Oct 27, 2009 | 11:24 AM
Alvyn's Avatar
Alvyn
what was the outcome on it m8?
Mark RS
Oct 12, 2015 06:01 AM
Steve Escos
Oct 1, 2015 06:57 AM
DAZZER
Sep 30, 2015 08:43 PM
