bloody banjo, help!!
Old Oct 12, 2009 | 03:18 PM
moondust-saph's Avatar
moondust-saph
moonstone-saph
Default bloody banjo, help!!
right every1 lol i had a go at taking the turbo off to get to the banjo shoen in the picturem i cnt seem to gt the turbo off, i tried both parts of the manifold shown, cud someone please tell me what have to do to get to the banjo shown for the water, as i need to replace the copper seal thanks
tried undoing these but were very tight:
these wnt budge4 big ones to the turbo
and the banjo im trying to get at:
Old Oct 12, 2009 | 04:31 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
take turbo off engine, undo manifold bolts to turbo.
undo exhaust housing bolts and rotate the core, it will be very stiff mind you.
or better still just take turbo off and take to turbo place locally, they'll get the bugger changed pretty easily for little money.
Old Oct 13, 2009 | 10:59 AM
moondust-saph
moonstone-saph
I'm confused, maybe its me but I didn't make sense of it matey, I need the 4 bolts off the turbo~manifold? Cheers
Old Oct 13, 2009 | 06:59 PM
Firstly the washer can be replaced WITHOUT taking off the turbo, by using a 12 point flat ring spanner, as there is enough space to get enough "swing" at the front and rear, ie facing the turbo from the offside put the spanner level so it is horizontal, it's a squeeze but do able and bloody fiddly.
The turbo is easy to get off by undoing drain, oil feed pipes etc and then the four nuts using a spanner, or alternatively just unbolt the trousers and remove that way, as the trousers bolts/nuts are much more accessible.
Once you have the banjo off, weld a tall nut to the banjo, so it sticks out further, I did this to both of mine and it is kids stuff to remove them now if needed.
Old Oct 14, 2009 | 03:53 PM
moondust-saph
moonstone-saph
ill give this a go, thanx very much, so i have the spanner faceing the bulkhead yeah?
Old Oct 14, 2009 | 07:01 PM
Try either way, facing the bulkhead or the front, after disconnecting the water feed pipe from stat housing.
A flexi head ratchet spanner can also be good here.
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
Bailes1992
Sep 3, 2015 02:17 PM
