ka wont start
Old Oct 12, 2009 | 10:34 AM
domerj's Avatar
domerj
Default ka wont start
wifes ka wont start!!!!
she called out aa who just bumped it to get her home.
turn key dash lights up imobiliser light on clock goes out turn key to next position dash lights go out and nothing!
have charged battery checked fuses relays look ok no corosion, have heard theres relays under the bonnet wheres there location?
anyone got any ideas????
Old Oct 12, 2009 | 07:36 PM
thfc4443's Avatar
thfc4443
Hi Mate, does it even try to turn over?
If not it sounds like an immobilzer issue
Old Oct 12, 2009 | 07:45 PM
domerj's Avatar
domerj
imobiliser light goes out when key turned,been told to check wires to starter
Old Oct 12, 2009 | 08:13 PM
Alvyn's Avatar
Alvyn
check the wires at the battery terminals are tight also and that the thin wire on the starter motor is connected!
Old Oct 13, 2009 | 07:09 PM
So just to clarify, in the sprung loaded START position the dash lights go out ?
If it was a bad starter it would draw no current from the battery and so not cause dimming/going out of the dash lights.
If this is the case, it sounds like a knackered battery, or majorly bad connection, try hooking up a mates jumpack to it and try again, if the battery is flat/duff they(starter solenoid) usually clicks rapidly.
Another option as it's a ford is the ignition switch contacts burnt out, anyone with basic electrical knowledge would soon get you moving.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
