Where is the fuel pump located on a Fiesta RS?
Old Oct 12, 2009 | 09:38 AM
Shep_Cobain's Avatar
Shep_Cobain
Default Where is the fuel pump located on a Fiesta RS?
Just wondered where the Fuel Pump in on the FRST?
Not had a search for it yet but just wondered if its in the same silly place as the Escort RS Turbos?
How easy is the fiesta one to change?
Thanks.
Old Oct 12, 2009 | 09:42 AM
bud-weis's Avatar
bud-weis
Football Cwazy
It's an in tank pump matey, so a little trickier to change IMO than an Escort RS!
Old Oct 12, 2009 | 09:45 AM
Shep_Cobain
Most definitely, so how do you change it it? On a ramp and get access to the tank where?
Thanks mate.
Old Oct 12, 2009 | 09:57 AM
bud-weis's Avatar
bud-weis
Football Cwazy
Thanks mate.
Im going from memory (which is pretty poor lol)
You have to drop the tank, then remove the cover off the top of the tank to get access to the insides. There is a clip that holds the cover on, i think i used a hammer and chisel or summat to gently tap it round to remove it.
Its an easy ish process from memory, although my FRST was concours mint so everything was nice and easy to do!
Old Oct 12, 2009 | 10:01 AM
bud-weis's Avatar
bud-weis
Football Cwazy
My memory is also saying there are 4 bolts holding the tank on, you obviously need to remove the filler neck which is a little tricky but not difficult...do take extra care with the small black cylinder which clips onto the inner arch. I believe its there to stop fuel leaking out should the car rollover, but if you break it then you can get problems with fuel starvation and possible meltdown!!
Old Oct 12, 2009 | 08:40 PM
cabriolet's Avatar
cabriolet
just had the tank out er indoorss escort same way of doing it the two bolts nearest the wheels collect crap over the years clean them as much as possible then squirt them with something several days in advance once the captive nut on the bracket spins get the saw out its in a bastard of a place to get a hacksaw in u been warned fella the pump is held in by a ring as already said tap it round with a hammer and a punch and bobs yr well u know
ekjim
Aug 27, 2015 05:20 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
