Weird turbo config
So,
Was messin' about reading how turbos work, tryin to understand different housing sizes, compressor trim and stuff, came accross this
I now understand whats wrong, and laughed when i realised.
Guess many peeps here will spot the mistake immediately, but thought it was worth a look anyway.
Seemingly as air flow follows the path of least resistance, it'll all escape through the bigger turbo, causing the smaller one never to spool up. Completely useless.
Just thought it was a mad pic.
Think it was designed for a C20LET
It's a bad setup I agree.
It's nowhere near as complex as something i'm working on
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Also - i can't help but wonder how turbulent the air would be trying to turn 90 degrees as it enters each turbo!
AMS seem to do a better job of twin turbo setups
Would the smaller turbo feed the larger one all the way through the rev range?
just seen this...
http://www.amsperformance.com/top_shop.php
just seen this...
JK12
33
Apr 26, 2021 12:09 PM
