bit of white smoke
Old Oct 10, 2009 | 05:59 PM
mk1trb's Avatar
mk1trb
Boost Junkie
Default bit of white smoke
well i finished my estate last weekend, been using her all week covered about 500miles, its mfi and i'm getting a little white smoke out of exhaust when you let off and throttle up again, now i instantly thought turbo but it only does it when your driving below 3000rpm and turbo not boosting, when you use the boost it doesnt smoke at all, any ideas???
Old Oct 10, 2009 | 07:04 PM
studabear's Avatar
studabear
white smoke could be condensation,
does it smell like burning oil?
Old Oct 11, 2009 | 09:05 AM
marky_g's Avatar
marky_g
Fleet Manager
or fuel, might be running rich
Old Oct 11, 2009 | 10:17 AM
mk1trb's Avatar
mk1trb
Boost Junkie
does it when engine up to temp and your driving in traffic mainly
Old Oct 11, 2009 | 10:52 AM
crazycage's Avatar
crazycage
fuel would be black smoke, could be nothing or could be head gasket
Old Oct 11, 2009 | 09:53 PM
darrenb16two's Avatar
darrenb16two
White smoke is water! Have you checked the water level? What headgasket is it?
Old Oct 11, 2009 | 10:49 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
could be just condensation in exhaust, crap fuel in tank, HG at worst.
Old Oct 12, 2009 | 06:26 PM
mk1trb's Avatar
mk1trb
Boost Junkie
i fear head gasket as there is a small patch of oil jus below the head near the cambelt on the front of the block, she doesnt overheat and heaters stay red hot, so could be early stages yet, i only ever use vpower fuel and its defo thick white smoke, defo not condensation
Old Oct 12, 2009 | 08:05 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
oil could be from rocker cover gasket, they all go eventually.
take it for a spin, will take a few hours of idle or a good run to clear condensation/water build up in the exhaust system.
Old Jun 15, 2012 | 07:56 PM
mgtkr1's Avatar
mgtkr1
i know its an old post but i have the exact same symptoms. since using a sensible oil 10w40 from 5w30 its calmed down hell of a lot in just 10 miles. what was the problem, did you get to the bottom of it?
Kyle Langford
27
Aug 5, 2019 07:54 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
john_3.0s
Aug 16, 2015 06:40 PM
nick8saff
Aug 16, 2015 05:35 PM
