boost
Old Oct 10, 2009 | 05:13 PM
asborsturbo's Avatar
asborsturbo
Default boost
hi my car is running just under 1.0 bar boost which is 14.7 psi i believe so about 14 psi. I have a pace intercooler, chipped ecu, -31 collins acuator mongoose exhaust, bailey dump valve and persume all internals are standard coz no recipts to say otherwise. I just had a new gearbox and clutch fitted but do u think i am ok running this boost thanks
Old Oct 10, 2009 | 05:17 PM
crazycage's Avatar
crazycage
all depends !!! did you just turn it up to that or was it set up ??
Old Oct 10, 2009 | 05:23 PM
asborsturbo
i got an escort rst btw. Erm i brought the car and it didnt have a pipe coming off the acuator to the vacum and was running max which was 1.5 bar on my gauge so thats y i had a new box n clutch coz it ruind the box. So wen they did the box i told them to turn the boost to 12psi but they said they added the pipe so it would be running standard but it goes up to 1.0 bar which is 14 psi
Old Oct 10, 2009 | 05:25 PM
crazycage's Avatar
crazycage
1 bar of boost is fine but the car will need a set up on a rolling road or you will end up with melted pistons
Old Oct 10, 2009 | 07:08 PM
asborsturbo
ok thanks but do u rekon it will be ok for a week til i take to oddkidd creations to be set to 12psi and a tune?
Old Oct 10, 2009 | 07:10 PM
DazC's Avatar
DazC
Yes but don't thrash it until it's set up.
Old Oct 10, 2009 | 07:37 PM
asborsturbo
ok how much does this cost thanks and do u know newhere near kent?
Old Oct 10, 2009 | 07:46 PM
orionmojo's Avatar
orionmojo
mines running:
Standard bottom end
stage 2 NMS head
Custom NMS chip
-31 actuator on standard turbo
Stainless 'zorst
Standard icooler
IB5 gearbox with LSD
B+M Quickshift
No Dumpvalve
My boost is 1BAR, approx 14.5psi. Ollie at NMS set it at that via a bleed valve, but told me not to hold it on boost in 4th and 5th for long blasts cos i will melt something, BUT for short blasts its fine, and its lovely to drive, nice and tame in traffic, but pokey enough to annoy most bmw diesel drivers
Old Oct 10, 2009 | 09:53 PM
asborsturbo
lol sounds gd il stick to that til i get it done. Does anyone know where to go for this set up im in kent thanks
Old Oct 10, 2009 | 10:05 PM
studabear's Avatar
studabear
take it to jano oddkidd in essex
Old Oct 10, 2009 | 11:41 PM
RSMK4TURBO's Avatar
RSMK4TURBO
SETUP!on rolling road mate will transform the car,just had mine done and what a difference.
Old Oct 11, 2009 | 07:21 AM
asborsturbo
roughly how much is the setup on the rolling road?
Old Oct 11, 2009 | 08:29 AM
crazycage's Avatar
crazycage
about £120
Old Oct 12, 2009 | 11:07 AM
O.K.C's Avatar
O.K.C
Eruption 101.3fm
Does a rolling road give you REAL ROAD conditions.?
Old Oct 12, 2009 | 11:43 AM
matt p's Avatar
matt p
Id like you to explain this Jano.
Old Oct 12, 2009 | 11:53 AM
Chris69's Avatar
Chris69
where did that come from, the kiddy wants his RST setup so that its safe etcetc - a RR setup by a decent tuner is perfectly capable of doing this.
Old Oct 12, 2009 | 12:23 PM
Rs Cosworth 1's Avatar
Rs Cosworth 1
RS for life
Norris motorsport mate,
MSD (if they do it)
Jano's well TBH that's your choice we all have our fave tuner's as such mate
Old Oct 12, 2009 | 06:16 PM
asborsturbo
so jano can do the rr setup can he? If not do u know any that are in kent
Old Oct 13, 2009 | 10:53 AM
O.K.C's Avatar
O.K.C
Eruption 101.3fm
Its Danny not Jano.
Common sense really pal.
A rolling road has no drag, friction, air flow, weather conditions etc etc etc.. That you have on a real road.
Any decent RR tuner would test what they have done on the REAL ROAD after. Making sure what they have done is relevant to what actually happens when driving.
The basics is this, a RR saves alot of time for the tuner. This is because the tuner does not need to keep going backwards and forwards to the workshop to edit the map write a new chip etc get back in car and test again.
The next thing is you get a graph of the power you have gained lost whatever..
If the RR operator wants to show higher or lower power than what is actually available this is easy to do. So are you the customer getting a true figure?
My advise would be go to a decent Tuner like Jano, Ahmed, Stu@Msd, NMS etc who will map the cars on the real road in real conditions.
Then if you wish to have a power run done to see what power you have, then do so at a low cost of around £40-50 on most Rolling Roads.
If thats how the best have been doing it for this many years surely that give you an idea to why....
much love Daniel.
Old Oct 13, 2009 | 04:15 PM
darrenb16two's Avatar
darrenb16two
I agree with Danny. Got mine done on the rollers at sanspeed in bexley heath, kent & he to took the car out on to the REAL ROADS twice to check the tweeks he made on the rollers worked on the road aswell.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
