ACT Gauge Opinions or Experience
Old Oct 6, 2009 | 07:20 PM
THEDMAN's Avatar
THEDMAN
Default ACT Gauge Opinions or Experience
Anybody have any experience of this?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
Old Oct 6, 2009 | 07:45 PM
DanRSturbo's Avatar
DanRSturbo
Awesome bit of kit
Old Oct 6, 2009 | 07:50 PM
Rs1's Avatar
Rs1
I'd just get one from R and B Motorsport, does what you want and is a reliable piece of kit.
Old Oct 6, 2009 | 07:55 PM
DanRSturbo's Avatar
DanRSturbo
That's where mine came from, and it was cheaper then the one on e-bay
Old Oct 6, 2009 | 08:05 PM
stu21t's Avatar
stu21t
that shows the middle of the gauge as 25-50 degrees c and as preffered temps
i thought low 30s was ideal (33) am i correct?
dan -1 is a bit cold m8.
Old Oct 6, 2009 | 08:17 PM
rs_daz's Avatar
rs_daz
That ebay one looks tacky as fuck.
The RB one looks better and is what I had in my old rst years back.. Shame the price on them has gone silly imo £70 odd.
Old Oct 6, 2009 | 08:23 PM
andybrst's Avatar
andybrst
You can get them from maplins for nomore than £15
Old Oct 6, 2009 | 08:25 PM
THEDMAN's Avatar
THEDMAN
Thought they were £72.50?
http://www.randbmotorsport.co.uk/sho...?ProductID=449
Old Oct 6, 2009 | 08:53 PM
DanRSturbo's Avatar
DanRSturbo
That's a lot newer then my one
Old Oct 7, 2009 | 06:11 AM
gibbo frst's Avatar
gibbo frst
A mate of mine has the eBay one on his cossie and had to wedge the thermocouple bit into a boost hose but it seems to work well but he had a guy off eBay say the metal thermocouple could break off and go into the engine and that they are designed to be fitted to computor cabinets not cars
Old Oct 7, 2009 | 07:53 AM
Graceland's Avatar
Graceland
Team HOTHOT!
Got that in my Cossie - superb little gauge and accurate too and fit perfectly where the dashboard light dimmer used to be (had to file 2mm out of the hole and cut the little fins off the gauge case) - I'll get a pic if you want?
Although I didn't fit the sensor as he describes in the instructions, I modified a BSP tail fitting to house the sensor in allowing the probe to protrude about 5mm into the plenumn. To do this I filled the BSP fitting with Sikaflex and then pulled the probe through it wire first and then crimped the tail fitting to secure the wire to stop the probe being blown out or sucked in under boost/vacume - The sikaflex cured to creare a perfect air-tight seal and a nice finish with the sensor now being easily removed with a 12mm spanner
Old Oct 7, 2009 | 08:39 AM
You can also get some from www.dealextreme.com that will tell you inlet temp and outside temp, as well as clocks in various different colours, for around £8-£10.
Old Oct 7, 2009 | 12:24 PM
Bobby Singh's Avatar
Bobby Singh
I've had one these monitors and they work ok but not with water injection (it goes blank). I discovered its actually a PC temp monitor that runs on 5v so you could just get a monitor from here: http://cgi.ebay.co.uk/Digital-Thermo...d=p3286.c0.m14
and then build something that will lower the voltage from 12v to 5v (this is exactly what you get when you pay £35 plus for ebay ACT monitor)
I would have been happy with the ebay jobbie if it worked with Water/meth injection. So in the end i got one from Mike Rainbird. Its expensive but it is a quality item:
HTH
Bobby
Old Oct 7, 2009 | 12:30 PM
PhilCook's Avatar
PhilCook
Or you could use for both sides of the cooler, see how efficient its working
Old Oct 7, 2009 | 12:43 PM
GribbiN's Avatar
GribbiN
I got mine from mike also, Great service and would recommend to anyone. I got constant emails and updates to my order. I even changed my mind about the back light colour and he sorted it all out no problem. Fits and works perfectly.
Old Oct 7, 2009 | 12:50 PM
red rsturbo's Avatar
red rsturbo
HTH
Bobby
where that screw in?
Old Oct 7, 2009 | 12:54 PM
GribbiN's Avatar
GribbiN
I tapped my inlet manifold
Old Oct 7, 2009 | 01:03 PM
Bobby Singh
Just drill and tap into the inlet:
Old Oct 7, 2009 | 01:20 PM
red rsturbo
kool
Old Oct 7, 2009 | 01:38 PM
T28 RST's Avatar
T28 RST
Ok then
Would love to see your temps Darren with the boost your using on a standard cooler
Old Oct 7, 2009 | 02:08 PM
fiend's Avatar
fiend
You would need an ACT gauge with two external probes for that though or two ACT gauges?
Old Oct 7, 2009 | 02:10 PM
Graceland's Avatar
Graceland
Team HOTHOT!
2 probes, 1 guage and a changeover switch between pre and post intercooler would surfice
Old Oct 7, 2009 | 02:20 PM
fiend's Avatar
fiend
I'm tempted to do this now, would be interesting to see how efficient my intercooler is.
Old Dec 3, 2009 | 05:04 PM
mattman1234's Avatar
mattman1234
hello all
can anyone give me examples of their before and after temps,i have fitted one of those act temp gauges,and not sure how efficient my intercooler is going to be,i have just rebuilt engine ,therefore i can't try on boost yet,but normal driving it reads approx 31 before and 14 after.does this sound about right.In in a dax rush by the way,with a non standard intercooler,which i had made
thanks matt
Old Dec 3, 2009 | 05:56 PM
JamboRS's Avatar
JamboRS
focus rs 1672
Originally Posted by mattman1234
hello all
thanks matt
grs on a rst
my r&b act gauge was spot on
Old Oct 13, 2012 | 03:13 PM
Cossy Mike's Avatar
Cossy Mike
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Oranoco
12
Oct 2, 2015 02:18 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
