Fiesta t3 conversion question?
So i just wondered, ive had to buy a new air filter for my fiesta turbo which has the T3 conversion.
I have bought this pipercross one: http://www.pxmedia.co.uk/getimage.as...27_after&w=500
But wondered what the best hose to use was to connect the turbo, the standard air box hose as the turbo's diameter is different to the air filter i have purchased.
Also, will i have to block up the pipe coming from the rim of the air filter which you can see in the picture?
thanks
thanks
If you are not using the smaller pipe fitting yes needs to be blocked as will allow unfiltered air in.
For the best pipe just get whichever has the smoothest route, and smoothest insides.
liamT74
Sep 23, 2015 10:24 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
