mondeo problems grrr mot wise
got problem with old mondy
she failed on the mot with to high a co reading the limit is 0.3 and she is up around 0.4-0.6
the car is running induction kit, 4.1 manifold,highflow cat,cams,pulleys
the car has had lambda sensor replaced when the system was fitted sensor is about 1year old as the old one failed the car has had maf unit, has had a new ect sensor last weekend with spark plugs etc all of these mods was on the last mot and passed first time last year
any ideas?
any ideas?
hi its a long shot but is your imrc working ok as if its jammed closed i think this will make it run ritch and on a lot of ford st cars they fail speaking from experience im about to foot the bill to fix mine on the focus st just a thought mate ?
Did you get the cat hot enough?
Just running it up on the ramp isnt always enough.try blipping the throttle at 4-5000rpm for a minute or so to inject raw fuel into the cat which burns in there and gets the cat very hot.
wont be running imrc as its a 2.0 16v silver top zetec
the car was driven hard all the way up to work which is about 21 miles way
made no difference also tried some super unleaded to still made no difference
these mondys are always close to the limit on co for some reason, 1 i owned about 2 years ago only just made it through. surely that high flow cat wont be helping as the car is a year older now
turned out to be my highflow cat had failed, so a new has been fitted with a new flex pipe and the car is back on the road with full mot for 12months so iam really happy about that .
thanks to any one who posted on this topic !!!
