414bhp Harvey Gibbs Cosworth Engine (Spec Added), L8 ECU, GP A Coil and more...
Im selling the 414bhp Harvey Gibbs engine out of my Ford Escort RS Cosworth.
Spec:
T34 turbo with .55 exhaust housing
Multi layer WRC Mountune head gasket
6 long studded new 200 block
Nick Wapples Ported head
Harvey spec Cams, double valve springs
7.4:1 low comp pistons
Lightened & balanced bottom end
Ice Blue 400 injectors
Matched manifolds
4x4 exhaust manifold
4x4 inlet manifold & throttle body
Dyno'd by Harvey, mapped by Ahmed Bayjoo with chip for L8
Harvey Gibbs spec'd engine with proven 414bhp/402lb ft torque - Proven 0-60 in 3.94 seconds (Performance Ford Vital Statistics - Jay Brown) - Very fast and pulls like a train to 130mph (Top end of 4th gear and was never given more than 1/4 throttle in 5th)
Things Ive done since I brought the car:
Running Mobil 1 Motorsport 15w-50 oil (Changed every 2 months)
New lifters
Replaced cambelt twice (The last one was done this week)
Uprated turbo wastegate penny
New water pump
Supplied with the engine is:
Cylinder head (complete with cams etc)
Block (complete with internals)
Dizzy
Inlet manifold
Exhaust manifold
Turbo
Cam cover
Complete engine basically, built, ready to drop in & plug & play as long as you have an L8, 4x4 fuel rail & 3 bar (Not inc. in sale)
I will need to remove the oil pick up and big wing sump as I maybe buying a 2wd engine and will need to convert it to 4x4. If I can find replacement parts at a good price I will buy and fit them.
£4000ono
If you want any background info or to check pedigry on this engine please feel free to contact Harvey himself, Mike Rainbird, Dingy, Big Nige or the guys from SCS mentioning its my car (escy without the spoiler) or Jay Browns old car (previous owner)
I am also selling:
L8 ECU
3 bar map sensor
Ignition amp and bracket
2wd Engine loom
Group A Coil (Brand new from Amber Performance last week) - £30 delivered
Please contact me (Steve) on 07732 872 122 or EMail me at FletchCossie@Googlemail.com if you need more info.
Spec:
Matched manifolds
New lifters
New water pump
Dizzy
Inlet manifold
Exhaust manifold
Turbo
Cam cover
£4000ono
I am also selling:
L8 ECU
3 bar map sensor
2wd Engine loom
This is the bollox of an engine & has done virtually no miles in the last 3 years !!
Built by 1 of if not the best engine builder in the uk & is bullet proof !!
Absolute bargin !!
Stephen, get some pic's up !!
jb
Absolute bargin !!
jb
JoeyBoyden
Jan 4, 2024 02:36 PM
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
