escort van
Old Oct 5, 2009 | 05:15 PM
skimonkey's Avatar
skimonkey
Default escort van
can anyone advise. can I replace the non turbo diesel engine in my escort van with a turbo engine ?
Old Oct 6, 2009 | 06:41 PM
Yes, but a bit more to it than meets the eye, ok if you have both vans side by side while you do it.
Another option is to N2O it, diesels respond exceptionally well to this.
Old Oct 6, 2009 | 06:51 PM
jammerrs's Avatar
jammerrs
turning the fuel pump up also common on diesels i beleive
Old Oct 6, 2009 | 07:19 PM
Roscopeco's Avatar
Roscopeco
P8 Managed S1 with ALS
You can turn the fuel pump up but ive done it to not much gain ! I was planning on the turbo diesel swap but was told on here that they would fit straight in no probs but would need the code reader for the key bypassed ! Hope this helps !
Old Oct 6, 2009 | 07:45 PM
jonny s2's Avatar
jonny s2
mk1 and 2 mondeo td engine will go in but what wiring will need to be done if any to a mk4 van,has anyone done this?
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
markk
Sep 9, 2015 08:11 AM
imnoteasy
Sep 7, 2015 09:26 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
Bighandsuk
Sep 2, 2015 05:23 PM
