iveco 2.3 16v 2003 won't start
Old Oct 5, 2009 | 03:18 PM
Doug2300's Avatar
Doug2300
sidewaystastic
Default iveco 2.3 16v 2003 won't start
Anybody got any ideas on why an iveco 2.3 16v common rail diesel. The problem is there is no injector pulse on crank. I have had the high pressure pump checked and also the injectors by a specialist. The low pressure pump seems to be fine. No fault codes of any use either. Also changed crank and cam sensors no difference. If easy start is used it will start and run fine?? Please any ideas as it's driving me mad.
Old Sep 20, 2011 | 08:37 PM
rscos2004's Avatar
rscos2004
i know this is an old post did u sort this out cheers.
Old Sep 21, 2011 | 07:02 PM
Doug2300's Avatar
Doug2300
sidewaystastic
Although the battery seemed to be o.k the voltage at the ecu was to low to switch on when cranking. Jump leads made no difference nor did a booster pack. The only option was a new battery and this fixed it!!!
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Bailes1992
Sep 3, 2015 02:17 PM
kevin36
Sep 2, 2015 06:24 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
