PassionFord - Ford Focus, Escort & RS Forum Discussion (https://passionford.com/forum/index.php)
-   Technical help Q & A (https://passionford.com/forum/technical-help-q-and-a-14/)
-   -   iveco 2.3 16v 2003 won't start (https://passionford.com/forum/technical-help-q-and-a/320940-iveco-2-3-16v-2003-wont-start.html)
Doug2300 Oct 5, 2009 03:18 PM
Anybody got any ideas on why an iveco 2.3 16v common rail diesel. The problem is there is no injector pulse on crank. I have had the high pressure pump checked and also the injectors by a specialist. The low pressure pump seems to be fine. No fault codes of any use either. Also changed crank and cam sensors no difference. If easy start is used it will start and run fine?? Please any ideas as it's driving me mad.:wall::wall:
rscos2004 Sep 20, 2011 08:37 PM
i know this is an old post did u sort this out cheers.
Doug2300 Sep 21, 2011 07:02 PM
Although the battery seemed to be o.k the voltage at the ecu was to low to switch on when cranking. Jump leads made no difference nor did a booster pack. The only option was a new battery and this fixed it!!!
© 2026 MH Sub I, LLC dba Internet Brands
