front bumper removal?
Old Oct 4, 2009 | 05:03 PM
moondust-saph's Avatar
moondust-saph
moonstone-saph
Default front bumper removal?
how does the front bumper come off? thankyou
Old Oct 4, 2009 | 05:35 PM
daz-cos's Avatar
daz-cos
theres a bolt just inside the wheel arch on either side behind the bumper undo these and it just slides of from the front dont forget to unplug ur spot lights first
cheers daz
Old Oct 4, 2009 | 07:45 PM
Just to add, the bolts will normally be seized solid in the captive threads, so will just spin and spin!!
Old Oct 4, 2009 | 08:02 PM
moondust-saph
moonstone-saph
Ill give it a go cheers buddie ur really helpful, I got to find a locking nut for the wheels as I cnt get them off lol
Old Oct 4, 2009 | 08:03 PM
moondust-saph
moonstone-saph
Ok ill give it a go, thabks ur really helpful bud. Where can I find the locking nut key for the original wheels I imagine these are what came from the factory
Old Oct 5, 2009 | 12:01 AM
SS1's Avatar
SS1
Maybe in your house somewhere
SORRY
Old Oct 5, 2009 | 10:03 AM
moondust-saph
moonstone-saph
Well seeing as I bought the car two weeks ago and it didn't come with 1...... Hmmm
Old Oct 5, 2009 | 08:20 PM
daz-cos's Avatar
daz-cos
fooook knows but u can do it on the ground just a bit awkward
Old Oct 6, 2009 | 06:33 PM
The easiest way is to lever the plastic guides out of the flaps that hang down from the wings, then just straighten after wards, drill out captive nut, then you can just about get a nut between the bumper and support bracket and hold there whilst putting a bolt through hole as normal, fiddly but that's how I do it.
For the locking nuts, often a(sharp) drift will do the job, but some may need a old bolt etc welding to them, just curl a bit of thin metal into a tune to protect the alloy, put over nut and weld inside a old bolt etc to it.
jessie_rs
11
Jun 3, 2019 04:57 PM
andy130
Mar 15, 2016 07:59 AM
Gary @ RS CLASSICS
11
Sep 10, 2015 06:49 AM
Aug 29, 2015 08:16 PM
