bleed valve and actuator rod length...
Hi all,
Currently when my car comes on boost it peaks at around 15-16psi but falls to 8-10 psi
It has a bleed valve fitted, is this a good idea? what would be the reason for the bleed valve if i can just adjust the actuator rod length?
Could the boost be dropping off so much due to the valve or could my actuator be fuc*ed?
I think the turbo is up to it, its a 2wd cosworth turbo with 360deg bearings.
Thanks very much
Rob,
Thanks very much
Rob,
cool cheers lads
I plan to fit an electronic boost controller (so i will be harassing you with questions soon Karlos!) but i would like to have the ability to alter boost setting between 10psi and 18psi.... will the -31 let me have that range?
Thanks again
Rob,
Thanks again
Rob,
lolYou want a Apexi AVC-R mate, the daddy of boost controllers!
Most peoples experiences are the opposite, although i've never had a problem with the Collins actuator I had fitted.
profec-B II
apexi AVC-R
gizzmo IBC
apexi AVC-R
gizzmo IBC
just about to buy a standard garrett -31, for the time being ie before i buy a boost controller etc i would like to replace all the smaller sized hoses ie too and from inlet manifold (the air bypass valve especially) and actuator hoses, any idea on where i can buy lenghths of black silicone hose in smaller sizes to suit the above.?
Cheers!
Rob,
these are the three i'm looking at too. As Karlos says the AVC-R does seem to be 'the daddy' however i have read some very good reviews on the gizzmo....
Cheers!
Rob,
Cheers!
Rob,
i have a load of blue silicon hoses a local place were going to throw away.
right money spent.... too much money spent
god i wish i could only buy one thing at a time on ebay!
Genuine garrett -31 actuator
Group a coil
New rocker cover
Ford gasket (bloody 30 quid with postage)
New ford oil filler cap
Silkolene Pro S oil
Gen ford fuel filter
and i had to physically stop my self from buying a new set of samcos! me thinks the gf is going to be less than happy, especially as i promised a no car weekend lol
Just going to replace the non silicone hoses as i go along... especially the ones to and from the amal and round the back of the inlet manifold.
Rob,
Group a coil
New rocker cover
Silkolene Pro S oil
Rob,
its bloody terrible. Probably buying a set of samco classics tomorrow depending on reply price lol. Making it look as standard and clean under the bonnet as possible for a difference. Means i can sell the vast quantities of chrome that came with the car!
Think the car still has a very small air leak from some where and its really annoying me trying to find it!
Rob,
Rob,
