How do you cure piston slap??
is there any way to stop it? i have a 4x4 saff and the noise cracks me up. im currently rebuilding the engine and was wondering if there anything i can do while the engine is out.
use 4x4 pistons iirc as the gudion pin is off set on them!
edit just seen yours is 4x4.......
is it a 200 block you have?
Excessive wear in the bore causes piston slap therefore if your rebuilding the engine surely you will have a rebore and new pistons thus getting rid of the piston slap. These engines didnt have piston slap when they came out of the factory did they! And a fully rebuilt engine should be as good as new.
Slap occurs when the pistons can move around too much in the bore, the 4wd has an offset gudgeon pin hole bore which cuts down on this, but if the pistons/bores are worn you can still get slap.
A correctly rebuilt 4wd motor on Mahle pistons with the correct piston to bore clearance (around 2 thou off the top of my head) wont have any slap at all even from cold.
As said, the problem was with the 2wd pistons the central gudgeon pin allowed the piston to rock in the bore, exaggerated as the engine wore. The 4x4 piston has an offset gudgeon pin to counter this , so when you get the block rebored and new pistons, it will be cured. However, I would still replace the little end bearings as well just to be on the safe side.
deathrider666
Sep 28, 2015 06:12 PM
timsrs
22
Sep 24, 2015 08:14 PM
..... Never wrong
