lethal xr3i. sliding all over shop
has'nt rainned 4 a while but as soon as it did the back end of the xr keeps wantin to skid out.. when u hit a bump on a corner or a painted line whilst on a round about.. scary as f***.. any ideas what would make the back end do this?? the tires are o.k 1 tire is slightly worn on inside.. im guessin it needs new rear dampers??
stripped down back end eveythin looks fine. bit of play in inner wishbone bushes. decided to scrap the lowered springs fit new gas dampers wid std springs along with new bushes.. hopefully it will sort it.. thanks 4 advise..
Has it got the right width tyres on the back? Often boy racers fit wider alloys that result in a tyre footprint that is too big (thinking it increases grip), but in fact it reduces the grip and makes the car lethal.
Put two bags of sand in the boot and try it.
after fitting new parts was bit better, had it nct (mot) today was told rear tracking was out?? was told that inserting washers between the rear tie bars would sort it.. anyone else done this b4??
Andypandy260
Sep 23, 2015 10:28 PM
