Electrical problems - COME GUYS REALLY NEED YOUR HELP..
Old Oct 1, 2009 | 01:18 PM
Mk1 Mex's Avatar
Mk1 Mex
Series One
Default Electrical problems - COME GUYS REALLY NEED YOUR HELP..
Afternoon all,
Dont suppose any of you have had the same issues i'm having at the mo.
Fault= No Dash Lights, No Drivers side rear lights, No number plate lights, No side lights. Keeps blowing the second 10amp fuse in, in the centre column of fuses. Altho main Driving Lights, Passenger Rear, Brake Lights and indicators all work fine?????
Thought i had resolved this problem and everything worked fine for about two weeks but attempted to drive home in the dark last sunday from me parents place and didnt have any of the above.
Going to pull it all apart tonight to find out wots going on, but some advise would be greatly received. Also have new stalks to try as well.
WELL PULLED IT APART / TRIED NEW STLAKS STILL BLOWING THE FUSES. CHECKED THE CONNECTIONS....
Getting really pee'd off as want to bring the car to the Essex meet on Weds nite ..
CheeRS
Barney
Old Oct 3, 2009 | 11:13 AM
MarkN's Avatar
MarkN
You must have a short circuit somewhere. Doubt its anything to do with the stalk as the other side would blow too.
I've seen this before when someone put a screw through a cable, and also where the number plate light wire chafed as it was coming out of the back panel.
I'd dismantle the rear light unit and check the wiring, - also check the number plate light.
Something behind the dash could also be responsible - as the dash lighting circuit is also run of the same fuse. Have you fitted a new head unit or anything like that recently? You could also check the lighting cable for the cigarette lighter and the drivers side front side light.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
c20tbo
Aug 17, 2015 10:19 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
