handbrake cable not releasing once handbrakes off
Old Oct 1, 2009 | 10:34 AM
ram's Avatar
ram
Has a large member
Default handbrake cable not releasing once handbrakes off
fitted my rear disc set up and it seems that when i pull the handbrake up it grabs the discs fine, but when i put the handbrake back down it doesnt want to let go of the discs?
i can push the cable pull thing on the calipers back down by hand and that releases them,
Theyre not seized and the cable moves freely in the sleeve.
all i can think is that ive fitted the handbrake adjuster incorrectly in the mounting point under the car and that the whole sleeve is moving when i release the handbrake, instead of just the cable inside the sleeve.
hope this makes sense! any advice or ideally a pic of the underside of a fez would be great.
going for mot tomorrow so need this sorted!
cheeRS
Old Oct 2, 2009 | 12:15 PM
Captain Cotswold's Avatar
Captain Cotswold
What rear calipers have you fitted?
Shows & Track Days
Apr 27, 2016 11:04 AM
muz
Sep 30, 2015 08:29 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Bransby
Sep 14, 2015 08:54 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
