tips please(500cooler)
Old Dec 23, 2004 | 05:24 PM
righthooker's Avatar
righthooker
Default tips please(500cooler)
easy way to fit ,as in from underneath or top rad out or not general advice please
Old Dec 23, 2004 | 06:08 PM
moonstone mike's Avatar
moonstone mike
Done mine from underneath really easy to do leave the rad in place good luck.
Old Dec 23, 2004 | 07:24 PM
simonc's Avatar
simonc
When i fitted mine to my 3dr i had to remove the radiator 1st, if i had to remove & refit it again i would remove the front bumper aswell next time to make it easier. You will only be able to get it in from underneath the car, jack it up & put it on axle stands. I put mine in on my own but it helps if someone can hold the i/cooler from the top whilst your bolting it up as its quite heavy to hold with one hand from underneath whilst trying to line the holes up. Mine was a radtec one & i had to trim the brackets down on the sides of the cooler to so it would line up with the captive nuts on the car.
Goodluck
Simon.
Old Dec 23, 2004 | 08:48 PM
G500COS's Avatar
G500COS
Give me your e-mail and il send you a step by step of how to do it as described in then cossie definitive manual.
Old Dec 23, 2004 | 10:13 PM
righthooker
email is in my profile mate
Old Dec 25, 2004 | 11:08 AM
moonstone mike
NO NO NO!!!!!!!!! you dont have to take the rad out and there is no point in removing the front bumper you are just making more work for yourself! the mounting holes are already there its such an easy job to do!
just place it up from the bottom job done
Old Dec 25, 2004 | 11:13 AM
moonstone mike
YES YES YES i did have to remove the radiator ill get my coat!!!
but there is a lot of work in removing the front bumper just for fitting the cooler.
Old Dec 25, 2004 | 11:35 AM
rapidcossie's Avatar
rapidcossie
i remooved the rad and go in from underneath.
prob didnt have to remove the rad but just makes it a lot easier...
Old Dec 25, 2004 | 05:34 PM
tont2002's Avatar
tont2002
g500cos, does that fitting guide also cover the saph?? If so can you e-mail me a copy of the guide mate??
Old Dec 25, 2004 | 11:06 PM
righthooker
so rads out loads of room now ,wouldnt have gone in due to the long inlet and outlet pipes still would have been a good idea to get some bolts and rubbers befor everywhere shut
car now on axel stands waiting for bolts
Old Dec 26, 2004 | 09:36 AM
moonstone mike
tont2002 i dont think the saph has the mounting holes there and you have to put them in yourself
Old Dec 26, 2004 | 09:39 AM
rapidcossie
the saf has the mounting holes!
Old Dec 26, 2004 | 09:41 AM
Filthy Rich's Avatar
Filthy Rich
The mounting holes are already there on the Saff, but had to remove the rad on mine.
Old Dec 27, 2004 | 11:07 AM
moonstone mike
whoops so the saph does have the holes then!!!!!!!!!!
Old Dec 27, 2004 | 10:26 PM
simonc's Avatar
simonc
Moonstone mike i'm not saying you have to remove the front bumper to fit the cooler but personally if i had to remove & refit it again i would, my front bumper comes off in less than 10 mins, once the grille is off its only 2 bolts by the headlights & turn a plastic lug at each end of the bumper, just means youv'e got more room & you don't have to jack the car up so much.
Simon.
Old Dec 28, 2004 | 10:05 AM
moonstone mike
tankybaby66
Feb 6, 2016 02:24 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
jonnyenglish
Sep 21, 2015 07:31 AM
Si B
Sep 12, 2015 06:49 AM
