Does the coilpack conv handle high boost and rpm?
Old Sep 30, 2009 | 04:54 AM
Lars_Ferm's Avatar
Lars_Ferm
Default Does the coilpack conv handle high boost and rpm?
Im intressted in trying one of the kits to p8 from msd but iv heard of some problems at high rpm and boost?
Old Sep 30, 2009 | 06:51 AM
If anything it will handle it better, as it will produce a stronger spark.
Old Oct 4, 2009 | 07:37 PM
Lars_Ferm's Avatar
Lars_Ferm
It should yes,but iv heard other stories.Thats why im asking.
Old Oct 4, 2009 | 08:03 PM
fatmike's Avatar
fatmike
I dont know wether the stories you have heard just relate to the p8, but I have the msd wasted spark kit on my cossy running a gt30 and it doesnt miss a beat
Old Oct 4, 2009 | 08:56 PM
hughy's Avatar
hughy
theses kits are the way forward mate, i know of few boys that has big bhp and have not missed a beat simply the best, hugh
Old Oct 5, 2009 | 07:13 AM
I run coilpack on a aftermarket ecu, they do seem to give a better spark, and this would tie in, as they came into mass use around the time of lean burn stuff getting common, which need a better spark to ignite ever weaker mixtures.
MSD do a lot of development before they release stuff, and don't do so until 110% convinced any and all problems have been ironed out, but still help in the even of a problem, which I must say I haven't seen with the coilpack conversions, seen some dodgy ford electrics though!!
Old Oct 5, 2009 | 08:12 AM
Stu @ M Developments's Avatar
PassionFords Creator
Hello,
I am not sure what stories you have heard but this system works perfectly well with all power levels. I am yet to experience any complaints from anyone with missfires at any power level.
We did had some issues with dwell time on revision 1, but that was fixed years ago and all drivers sold out into the marketplace upgraded free of charge to revision 1.1
Dont forget that with your P8 you can run the buiilt in drive system with a simple chip data change, although that will render you with no tach drive so you will have to spend some extra on a tacho if some wires and diodes dont work. (They often do)
Old Oct 5, 2009 | 10:30 AM
Lars_Ferm's Avatar
Lars_Ferm
Originally Posted by Stu @ M Developments
Hello,
Ok so it was the early version that there was a little problem whit.Is there a diffrence whit the chip to l8 and p8? is there a software mod in p8 and i have to add this to the L8? im on a msd 6a and msd ss coil now and i had to solder to my tacho to make it work so i think it will work whit coilpack.Il probably give this a try if u can convince me Is there anyway u kan make this work whit 4 separate coils? I know u can get a direct fire of the p8 box is that someting u been thinking of doing?
Old Oct 5, 2009 | 10:34 AM
Gazzonator's Avatar
Gazzonator
Gary Krishna
I've been running this system on my 4x4 saph at 450 bhp and had no issues whatsoever!
Quite possibly the best mod I have done to date!
Old Oct 5, 2009 | 10:41 AM
KSA-Cossie's Avatar
KSA-Cossie
I wouldn't have a cossie without w/s it transformed the car.
Old Oct 5, 2009 | 03:23 PM
focus 4x4's Avatar
focus 4x4
So whats best ? L8 or P8 particually if you want to run the coil pack conversion ? air injectors? 8 fuel injectors?
Old Oct 5, 2009 | 04:06 PM
KSA-Cossie's Avatar
KSA-Cossie
I'm gonna be running w/s and air to air on my L8 m8.
Old Oct 5, 2009 | 08:31 PM
Dave Hewy's Avatar
Dave Hewy
Ive got an msd wasted spark running 32psi on my t34 and it never misses a beat.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
