fly wheel
Old Sep 29, 2009 | 07:26 PM
mr_joe0606's Avatar
mr_joe0606
Default fly wheel
advanages off a lightend fly wheel?
Old Sep 30, 2009 | 03:11 AM
vivien62's Avatar
vivien62
oviously for more break horse power and less stress on the crankshaft,which can lead to knackered bearings,then ya rings,to scouring the bore liners,aagh..try 07786764561 the guy has a brand new helix aluminium/carbon flywheel,cost £350,selling for £300...
Old Sep 30, 2009 | 06:30 AM
Johnny Knoxville's Avatar
Johnny Knoxville
Wrong
They just make the engine rev freely
Thats why people think they make more bhp
Old Sep 30, 2009 | 06:55 AM
Very wrong, it cannot affect the bhp in anyway, don't listen to this yank shit that they normally spout.
It also doesn't "make" the engine rev freely, it helps as there is less rotational mass to accelerate, so less power is used up during acceleration of the engine/flywheel, but it has a major effect on engine liveliness with a good amount removed, as the engine will "see" a much much larger load lifted from it than the weight would suggest.
Old Sep 30, 2009 | 08:00 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
it reduces the moment inertia by lightening, so the engine has to do all the work in one go instead of using some of the stored energy in the flywheel.
when launching you build your revs then drop the clutch, in a normal flywheel there is a huge amount of stored energy, this helps give a big burst of power to the wheels and gets you off the line faster but since it's a 'heavier' flywheel it will reduce acceleration as the engine is not only moving the car but spinning a heavy disc which is building up energy.
alternatively you have lightened ones, the lighter or indeed ones with less moment of inertia, wil let the engine rev up faster as less energy is used in spinning the flywheel to store kinetic energy, however on a launch there is less stored energy in the flywheel so less instant energy to move the vehicle, although when the engine has dropped revs due to the instant energy transfer it can accelerate the car faster as less of the engines energy is used to spin the flywheel and thusly less energy stored in the flywheel.
that was a long one lol!
basically makes the engine more responsive, can make idle less smooth.
Old Sep 30, 2009 | 05:38 PM
mr_joe0606's Avatar
mr_joe0606
is it worth 1 wen i domnt intend in over 200 bhp and is the standard 1 fine???
Old Sep 30, 2009 | 05:40 PM
Johnny Knoxville
Thats what i meant to say
I didn't explain myself very well
Old Sep 30, 2009 | 06:32 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i didn't bother as the cvh efi one i'm using isn't exactly heavy and there is enough power to get the car spinning wheels anyhow.
if you want a smoother drive, don't bother.
if you intend to launch it from lights etc. a lot, then go for it.
Old Oct 1, 2009 | 04:06 AM
vivien62's Avatar
vivien62
who said there is no bhp to gain from lightening and balancing,a recorded bhp reading of350bhp at the flywheel will be a lot more different,by the time it gets all the way down to the wheels on the tarmac,where the recorded readout said 305bhp,so where did all that break horse power go to loss ?
Old Oct 1, 2009 | 04:41 PM
Johnny Knoxville
Transmission loss
Old Oct 1, 2009 | 05:30 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
as above, spinning aflywheel just turns kinetic energy into rotational kinetic energy, when you lift off the power, the power keeps shifting to the wheels.
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
JamboRS
28
Sep 14, 2015 09:02 PM
BRAM
Sep 8, 2015 07:11 AM
