zvh engine oil
hello people what i want to know is what engine oil do i use for my 1800 zvh engine???some people say 15w50!!!!some say 5w30!!!and some say 10w40!!now what do i use????
kool mate aint that abit to thick???i tried 15w50 valvoline oil and it didnt run all that good!!!!it done exactly what a old school ford machanic said!!!would cause miss fire....& he said 15w50 is like the 1st level of gear box oil!!!!
depends on the use of the car, everyday use would be fine for a semi 10w40 like millers.
for more abuse burtons recomend millers comp spec oil, 10w60.
my 1.8 zvh will be on this in a few miles, been run on 10w40 millers until now, but the power will be turned up with the paddle clutch now in place.
Oil grades are measured in centistokes and an ideal centistokes value is around 14cst at normal running temperatures so you really need to know what temperature you oil is getting before you choose.
When oil is quoted at 10w40 the 10 is the oils viscosity value at 40degC and the 40 is the oils viscosity at 100degC
The idea is to choose a grade that will give you this 14cst at your normal running temperatures. Im using 5w40 in mine as my oil temperature doesnt go above 100 so I dont need to go any higher. The 5 (as opposed to 10) just means its thinner when cold which gives better protection until the oil is at its normal temperature.
The table below shows various oils and their viscosity at various temperatures.
DegC...............0...............10............4 0..............100
0W/20............329............181...........46..... ..........9..
5W/40............811............421...........92..... .........14..
10W/50..........1039...........539..........117....... ......18..
15W/50..........1376...........675..........130....... ......18..
20W/50..........2305..........1015..........148....... ......18..
Hope this helps.
Sam.
Hope this helps.
Sam.
Any 15/50 or 10/50 fully Synth 3 Ester Oil will be fine, although i'd go for a 10/50 if you can get it as we are going into the winter months!
Remember that if your running any sort of decent boost your oil temp WILL be over 100deg if your driving hard, if you've got no water cooling on your turbo this again will mean higher oil temps, and again in the summer months you'll regualry be over 100deg.
IMO 10/50 is ideal, as this will get round the engine quickly on start up in the winter months (summer too
) and will still maintain a good viscosity when being driven hard
Like this.. http://cgi.ebay.co.uk/Silkolene-Pro-...d=p3286.c0.m14
blackbeautyzetec
Sep 11, 2015 03:10 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
JoeyBoyden
Aug 18, 2015 10:52 PM
