Big thanks, to Rich - Polished Bliss
G220 arrived today, safe & sound, just in time for the weekend!
Many thanks for sorting it out, cant wait to use it now!
Any tips anyone?
Thanks,
Gavin
Any tips anyone?
Thanks,
Gavin
Mark a line on the top of the backing plate with a perma marker and you can then use this to judge how fast the pad's rotating.
When you're using it, with the correct pressure against the panel, it should be spinning at least 1 full revolution per second (faster is fine). Slower than this and you're applying too much pressure.
Try to move the machine slowly - about an inch per second is good.
Start with the least abrasive polish and pad combo you have available as often less abrasive pairings are enough and you won't have removed unnecessary paint thickness.
You only need a few peas sized blobs of polish on the pad per section.
Work on small areas at a time (12inch x 12inch, or fractionally larger is ideal). That way you're working the diminishing abrasives down at roughly the same rate over the whole work area which is key to getting a marr free finish.
If I think of any more I'll post up
http://www.polishedbliss.co.uk/acata...es_polish.html
and here...
http://www.polishedbliss.co.uk/acata...e-faq.html#3.9
Mc5506
Oct 5, 2015 09:57 PM
The Enigma
Sep 29, 2015 10:31 AM
caprixpack
Sep 25, 2015 07:53 PM
