rs 1600i cutting out
Old Sep 24, 2009 | 08:26 PM
martin m murray's Avatar
martin m murray
Default rs 1600i cutting out
hi all just woundering if any body could help me with this problem i have.
from the start the runs and drives perfect apart from when im coming to a stop the car cuts out .basically when the car is runnin and i put my foot on the brake it cuts out.ive replaced all hoses and checked to see if they were in the right place which they are.
Old Sep 24, 2009 | 08:41 PM
patton16i's Avatar
patton16i
Back in business
iv got a 16i myself with a v,similar fault check the fueling out!They are fitted with a decelaration conponent [ecconomy lights on instrument pack]its possibly the component that controls them at fault.
Old Sep 25, 2009 | 06:26 PM
martin m murray
cheers thanks ill try that.
Old Sep 26, 2009 | 10:52 AM
If it's running lean, applying the brakes can make a difference due to servo, but is it at the correct idle rpm to start with, could just tweak the mix richer a touch will often help, but if valve knackered on servo pipe this will also cause it as it introduces a air leak when brakes are applied.
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
Fudgey
21
Sep 30, 2015 06:19 PM
chris m1
Sep 7, 2015 08:02 PM
