Dashboard Lights
Old Sep 20, 2009 | 10:19 PM
S2Steve's Avatar
S2Steve
Default Dashboard Lights
I seem to have 2 lights on permanently, one is th handbrake light, even if its fully down and as ar as i can tell not on at all. Also there is the light to the right (it looks like a skid rsk sign post?) which im not sure what is telling me?
Old Sep 20, 2009 | 10:26 PM
orionmojo's Avatar
orionmojo
My handbrake light was on all the time too, i took the bulb out
you could try the connection. if you take off the handbrake surround (if you have one) you can peel the carpet back just enough to see if the clip is on the spade connector. that'd be your first port of call anyway. it seems no matter what i did with mine i couldn't get the light to go out!
second is your ABS light. i have no experience of this as mine is an orion turbo conversion and never had ABS. if it has been removed, take the bulb out, if it hasn't then get it checked!
sorry if take the bulb out is abit cowboy, someone else might be able to help better
Old Sep 20, 2009 | 10:41 PM
S2Steve's Avatar
S2Steve
Hmmm abs lights doesn't sound good! I don't knw if it's been removed to be honest, brakes don't feel all that good, tends to pull either way under hard braking
Old Sep 20, 2009 | 11:42 PM
RAT8OY's Avatar
RAT8OY
The ABS light usually comes on when the belts become slack. I would pull the sensors out of the belt housings and close them by hand If the light goes out you know what needs sorting. Its also not unheard that the sensor itself goes tits up or suffers from dirty conections due to their location under the car.
The handbrake light can also come on when a low brake fluid level is reached (or under hardcore braking) so check the conections and sensor in the fluid res.
Old Sep 21, 2009 | 02:29 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
As the connection is internal I doubt it will be dirty. Most probably one of your belts has snapped or your microswitch has fallen out of the casing. The belt pushes on the micro-switch so if the belt breaks the circuit is "open" causing your light to come on. Again, if the switch has fallen out, the m/s will be open. Look under the car for a wire dangling down.
If it's fallen out, silicon around the edge once it's back in position. If your belt has snapped then either replace it or remove the system/ bulb should you feel the need. Bear in mind if you remove the bulb your abs will not function correctly and with the light on it will not pass an MOT.
Old Sep 21, 2009 | 03:30 PM
S2Steve's Avatar
S2Steve
Hmmm ok. Its got new pads and discs at the front "apparently". It doesn't feel like it, the brakes dont feel good even by 1980's standards.
Old Sep 21, 2009 | 06:45 PM
botters's Avatar
botters
competant bodger
then it probably still has abs fitted! if you remove the abs completly and re pipe the front brakes it makes a massive difference
Old Sep 21, 2009 | 07:04 PM
S2Steve's Avatar
S2Steve
Is there a guide to this? Does it involve bleeding the brakes?
Old Sep 24, 2009 | 03:49 PM
S2Steve's Avatar
S2Steve
Ok i've done some investigating. Theres no belts on the driveshafts so i guess thats why there ABS light is on. It seems long winded to bypass the system, fabricating pipes etc, is there an easier fix?
Also checked the connector on the handbrake, that is on it seems so not sure why the light is on for that?
Old Sep 24, 2009 | 03:58 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Is it the handbrake warning, or low brake fluid warning?
Old Sep 24, 2009 | 05:12 PM
S2Steve's Avatar
S2Steve
Its the one to the left of the abs light. Brake fluid is full.
Old Sep 24, 2009 | 07:20 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
If the ABS has a problem both of the lights come on.
Easy fix is to get belts fitted and ensure the microswitch sensors are both silicon'd in position to stop them coming out.
Have these just come on? Seems strange if they have yet you have no belts fitted. If there were no lights before then how have your belts just disappeared?
Old Sep 24, 2009 | 08:26 PM
S2Steve's Avatar
S2Steve
i bought the car with the light on and presumably no belts. Are the belts easy to fit??
Old Sep 24, 2009 | 08:32 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
In that case they prob snapped and previous owner couldn't be bothered to replace them. Did you not ask why they were permanently on before you bought it - could have used it to get some extra cash off?
They aren't difficult to replace but you will have to disconnect somewhere (can't remember off the top of my head) to slide the belt onto the shaft. Ok job if you have a ramp/ somewhere to do it.
Old Sep 24, 2009 | 08:46 PM
RSmark84's Avatar
RSmark84
as shawn mentioned. i just removed the abs light as one of my belt snapped before i brought the car.
Old Sep 24, 2009 | 09:54 PM
S2Steve's Avatar
S2Steve
Are there no mods that need to be done if the abs is in the system yet not functioning though? I think i'd rather put belts on but dont want to replace any other parts
Old Sep 25, 2009 | 04:36 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
You shouldn't need to replace anything bar the broken belts. No mods required.
Old Sep 25, 2009 | 07:08 PM
S2Steve's Avatar
S2Steve
Sweet, no bushes or anything once i take the shafts out?
Old Sep 26, 2009 | 08:41 AM
rs shawn's Avatar
rs shawn
S1 Database Editor
Fairly certain you don't - but is a long time since mine were done. Just disconnect where you need to, put the belts on, then refit what you've disconnected.
Old Sep 26, 2009 | 09:15 AM
S2Steve's Avatar
S2Steve
OK, and i presume its 2 belts, one on either driveshaft when the grooves are?
Old Sep 26, 2009 | 01:04 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
Here's a pic that might help rather than try to explain it in more detail.
Old Sep 26, 2009 | 02:20 PM
S2Steve's Avatar
S2Steve
Blimey
Steve Escos
Oct 1, 2015 06:57 AM
stevecfrst1
Sep 30, 2015 05:18 AM
deathrider666
Sep 28, 2015 06:12 PM
Sep 28, 2015 10:05 AM
