zetec turbo help
this would be my first engine build/ engine mod.
planning on using a 1.8/2.0 mk1 focus engine and plan putting it back in a focus. doing this on a budget so its a decomp plate and manifold adaptors from an engineering company... not sure if im allowed to say the name but you knw who i mean.
got a few questions before i begin any help greatly appreciated
1 what loom will i need. is stanadrd foci one ok
2 what ecu was think frst will this fit focus loom
planning a frst/erst exhaust man and turbo.. and a efi inlet from frst would this work out.
im easy enough undertsnding the guides online concerning head work and oil return/ feed for the turbo but its justthe injectors loom and ecu i need real help with. as i've said this is a budget test run zetec turbo and this is the part that is causing probs
thanks
blair
thanks
blair
